375hp vortec 400ci 2 bolt
420ft lbs torque
th700r4 stock
3.44 rear
should run ??? 14.5
14.0
13.9,,???
420ft lbs torque
th700r4 stock
3.44 rear
should run ??? 14.5
14.0
13.9,,???
just by going based on what you said about the HP and Tq. ratings i SERIOUSLY hope you run quicker than those times, if not something is really wrong
I can't agree more. I went 13.90 and my car runs like s**t. You should be EASY mid to low 13s with no traction at close to 110!just by going based on what you said about the HP and Tq. ratings i SERIOUSLY hope you run quicker than those times, if not something is really wrong
Pending you have traction or not you have a 12 second vehicle. The power numbers shown are easy 12's its just a matter of suspension tuning and some fat meats on the back
Actually hold on....what cam grind?? do you have a stall converter..probably not...so I'll adjust that too a low 13.
!! Actually hold on....what cam grind?? do you have a stall converter..probably not...so I'll adjust that too a low 13.
230,,,212,,or vise verse @0.50..its a low comp engine 8.74:1,,so i didn,t want an off the shelf cam designed for a 10.1:1 comp ratio,,,this cam opens fast and closses fast....simm ilar to the comp cams XE 280 hyd profile,,but better,,its more modern design,,,buy cam tec custom profile,,,sounds weird ,,,but we checked it when installed ,,its spot on,,,what he recommended,,
I didn't make it to the track last fall and my setup is somewhat similar. I am hoping for mid to low 12's with traction. Let me know if you guys think this is possible. See my sig for details.
yEH that thing will blow mine off the road,,,with the bigger heads more comp,,little bigger cam victor ,,,jnr 850 3.7.s..mine is like i mentioned low comp,,smaller cam mentioned above,,750 ,,holley 2116 edelbrock only good for 5000rpm,, cam will run up to 5400rpm,,,but ,,i would realy love to build a killer donovan 372ci like they run here in sprintcars,,,,soon they are going to 410,s ci, so many good parts will be up for sale cola cranks,, dart heads,,oliver rods,,you name it ,,,,everyone is stepping out of the 372ci into 410ci as the world of outlaws come down under,,in jan 2004,,,BRING IT ON,aussie steve:lala:
