Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
coilover spring rate?
Old Mar 20, 2003 | 03:33 AM
Kandied91z's Avatar
anyone know a good way to determine what coilover spring is right for your application?
Old Mar 22, 2003 | 02:37 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Its pretty much trial and error unless you can copy what someone else has tried. The rear of our cars is fairly simple because the shock angle mimics the spring positon and angle so they should be the same. I am currently working on a rear coilover set up and if I can get the coilovers custom built to my specs, I will be 1st trying 225# rear coilover springs- 2.5"diameter. I am price shopping right now and am not getting much imput in responses on custom built units.
Fronts will most likely stay a bit lower spring rate than the conventional springs you are currently using because the are mounted more outboard that the conventionals and don't have to be quite as stiff of a rate to maintain the current ride stiffness.
92projectcamaro
Dec 8, 2015 12:25 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
