Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/4 time, hp, and torque estimates?
Old Mar 23, 2003 | 09:12 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
as the title says, i was wondering what to expect as far 1/4 times, hp, and torque from my setup soon to be completed.
Engine- 350 block 2 bolt mains with .030 overbore, hypereutectic flattop pistons, crane cam with .467 lift on int/exh and 110 deg lobe separation, GM Vortec heads, power plus vortec intake manifold, edelbrock 600 carb, and a nice shiny air cleaner.
Exhaust- Hedman shorty headers, custom mandrel-bent 3" y-pipe, no cat, and flowmaster force II catback (30 series muffler).
ok, in addition to the stuff i copied from my readers ride page....this car is daily driven, and im trying to maintain tolerable gas mileage, so i dont want to go too overboard. i have a new distributor, wires, and spark plugs. it probably has around 10:1 compression. the ac, cruise control, and emissions equipment have all been removed. the transmission will be rebuilt with a shift kit and 2500 stall torque converter. the rear end will have a 3.73 rear gear ratio and positrac. im using regular street tires that were on the car when i bought it, and theyre in good condition. the suspension is all stock. thats all the details i can think of now. any suggestions for improvement are also welcome. thanks in advance for the replies.
Old Mar 24, 2003 | 01:59 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
It all depends on tuning but I would guess you should run a low 14 or high 13 sec 1/4 mile with street tires, traction will probably be your biggest problem. With some sticky tires you should be in the mid to low 13's. I would also think about moving up to a 650 holly carb if you want to improve your high rpm HP but its hard to beat the drivability of an edelbrock carb on a daily driver.
My guess on your power 350HP, 375ft/lbs torque
Old Mar 24, 2003 | 02:19 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: 1/4 time, hp, and torque estimates?
The 350HO crate engine is about the same as that with 9.1:1 and slightly less intake lift, and it makes 330 horsepower and 380 ft lbs.
Old Mar 24, 2003 | 11:23 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
definately get some sticky tires and traction stuff..you have a little hotter setup than I do and I do nothing but spin off the line...my 60' on my best run was 2.67
Old Mar 25, 2003 | 01:22 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
I'd say u could pull low 13s if u put new suspension and maybe a bushing kit, and some sticky tires
Old Mar 25, 2003 | 08:42 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
after the street tires are worn out, ill probably get sticky tires. i was thinkin i would get a lca with relocation brackets, adjustable torque arm, and sfcs. would those be the best choices, or should i go with a different combo? the adjustable torque arm costs $355 at spohn, and im not willing to pay that much money....so would it really be necessary?
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
evilstuie
Jan 9, 2020 08:29 PM
bellez77
Sep 5, 2015 08:39 PM
86White_T/A305
Aug 17, 2015 12:16 AM
gwade12
Aug 8, 2015 08:17 AM
