1/4 mile estimates, 305 TPI - 5 speed
Goin to the track this friday and wondering what you guys think I will run. I searched past threads and think I might come up with a low 15 second run. What do you guys think?
-1988 IROC-Z
-305 TPI / 5 speed
-G92 with 3.45 gear
-optioned without A/C (yeah its hard to believe, but it doesn't have factory A/C) so it doesn't have all that A/C weight
-Interior is stripped, theres basically only 2 seats and a dash.
-No known engine mods and it's a GM exhaust system.
-Brand new Z-Rated BF Goodrich tires.
The car is bone stock except for the weight reduction. What do you think? I'll post the results in a couple of days.
-1988 IROC-Z
-305 TPI / 5 speed
-G92 with 3.45 gear
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by 25THRSS
You sure its not a 1LE? They didnt have ac.
Originally posted by Apeiron
A lot of cars didn't have A/C, not just the 1LE's.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
comon guys...that car can run a 14.8 in its sleep...and youd have to be a sh!tty drive not to break a 14 in that car....
i granny shifted my ride the first few runs...14.8-14.7-14.68...the 60 fts from 2.02 to a 1.91
after i got consistent on my launch i beat on it for 3 passes...14.22-14.19-14.12 all at 95.5-96....only mods are a fartmaster, k&n, and minor plenum porting
car is a full weight 91 gta lb9 t-5 g92
(soon to be a full wieght LT4 t-5 g92)
i would expect a 14.7 or better
(edit was a typo)
(edit was a typo)
But as far as times go you think high 14's are possible??
Engine: CARBED LT4
Transmission: MK6
with the car running good and if you know how to drive it then i would be disappointed running anything over 14.8....
well thats me cuz i know what my car can run ya know?.....
but yea dude a high 14 is almost expected..
Well it turned out to be an ugly night.
I only managed one run since it was so busy and some guy in a 98 Z28 decided to slide into the wall and it took almost an hour to clean it up.
Race weight with me in the car and 3/4 tank was 3360lbs.
It was my first time ever running at a track. The run was 15.99@92mph. Obviously this sucked but the upside was the 92 mph trap speed. 60' time was an ugly 2.8 because I was fishtailing the whole 60'. I was so rushed I didn't even get to check my tire pressure or anything; they turned out to be at an ugly 35psi. With a trap of 92mph, I should hit 14's easily with practice. I really can't complain since this car is bone stock right down to the AC paper air filters
Suspension mods are next before I even think of hitting the track.
Engine: CARBED LT4
Transmission: MK6
see dude..you got the speed for a 14.8 right there
lower your tire pressure to about 28 psi or so..
how were you launching?,..i cut 1.9 60's on street tires with the stock bushings still in the rear suspension...so the rear suspension isnt as bad as people think...ive seen guys cutting 1.75-8 on drag radials with the stock bushings...
what rpm did u shift at?...did u go through the traps in 3rd or shift to 4th?
i have almost the same car as u, so im sure i can give u a few tips
Rob
Rob
I brought it up to 2k then I slipped it and pinned the gas. I was spinning both tires through the whole 60' almost. I think I need to practice a bit with the amount of power I need to lay down.
I was shifting around 5200 or so and I think I went through the traps in 4th gear.
Engine: CARBED LT4
Transmission: MK6
i do it one of 2 ways depending on track conditions
if the track is tacky, i hold the rpm's at 1,800-2,000..and i side step the clutch...one of 2 things will happen...if u drop it and floor it right away the tires are gonna spin...if u drop it and hold the throttle at 1/2-2/3's get to the tree then mat it...with my 3.42;s the tires dont spin very much and the r's jump right up to 5,200 and stay for about 2 seconds and then i leave it matted shift 2nd and third...
if the track i s greasy youll have to play with the clutch on launch
again hold the r's at 2 grand or so and when it goes green you wanna feather the clutch out about 75% and be at 60% throttle to the tree. then floor it and the clutch should be out already...now doing this method can wear out a clutch if not done properly...when u launch spin the wheels just a little bit to help the car get up and go
both of these methods have gotton me 1.98 and 1.92 60 ft.
i shifted to 2nd at 5,200 ,,into 3rd at 5,400 and shifted to 4th at 4,400....
HTH
Rob
HTH
Rob
Originally posted by Ian_F
I was under the impression that in order to have a 1LE, you needed to have an L98.
Engine: CARBED LT4
Transmission: MK6
my first time launchin the car at the track was a 2.4 60 ft..i ran a 15.2@93 mph
with a 2.2 it was a 14.8@94.....
and with a 1.92 60 ft and powershifting it ran a 14.12
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
so basically ya have a (what i'll consider) a 16sec car uh? thats real cool...
just messing with ya
Once I bolt on my headers, cam, port the plenum and AFPR I'm on the road to 13's!! haha
Sanjay
Aug 12, 2015 03:41 PM
