Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
traction issues
Old Jul 17, 2003 | 03:20 AM
mickman's Avatar
Car: 1991 Z28
Engine: 5.7L LT1
Transmission: 4L60
traction issues
I have a 1991 Z28. We just put a LT1/auto in the car. Also have 3.73's. Air intake, exhaust, stage 2 fast chip etc. I've tried launching the car a few times. Brake torqing is not going to happen. The car breaks loose and spins like crazy. Launching from idle spins but not as bad as I thought it would. It definately pulls harder from idle, front end jumps right up! I was thinking of going to Nitto drag radials but am worried about blowing the 7.5 rear end. should I be concerned, and how should I launch this car? I have firestone firehawks on the car right now. Thanks!
Old Jul 17, 2003 | 06:03 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Factory rear longvity is kinda of a trick question when you start putting power to it and traction. Some guys frag them for no good reason and others like me have had pretty good luck so far-knock on wood. Second season racing with this factory rear, consistent 1.80 shorts, I'm not 100% confident with this rear as I'm just waiting for that time when it let's go, but so far so good.
Old Jul 17, 2003 | 07:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stiffening rear cover and welded tubes go a long way in helping them last. Any hint of wheel hop must be eliminated (poly bushings, boxed or tube LCAs).
Old Jul 17, 2003 | 07:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran mid to low 11's on a modified 7.5". Solid rear cover with bearing cap supports. Solid crush sleeve. Welded tubes. Aftermarket 28 spline axles. 4.10 gears.
I was getting low 1.7x 60' times and ran it for about half a season. I switched to a 9" when I installed a transbrake.
MM2Robinson
Oct 1, 2017 09:16 AM
Numbah-1
Sep 12, 2015 08:57 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
dbrochard
Sep 7, 2015 09:41 AM
