Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Holley 750 leaking
Old Jul 20, 2003 | 11:52 PM
1986redbird's Avatar
Holley 750 leaking
Hey guys, my holley 750 VS. has developed a leak, it only seems to leak when the car is first shut off, it leaks from the secondary shaft (where the vacuum unit is attached), until the rear bowl is empty. i have opened the carb up and can't find any sign of where it could come from, all the gaskets are new and the bolts/screws are tight. I don't see any cracks or anything obvious for causing the leak but it runs down onto the intake and into the intake which makes the motor hard to restart (flooded). any body have a similar problem that can clue me in??
I have checked the fuel level when running but I don't see how too high of a level could make it drain the entire bowl when off.
Old Jul 21, 2003 | 12:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looking through my Holley book I can see all the fuel passages go up through the metering block so leaking down can't come from them. If nothing is cracked, there's only one place that fuel can drain from the float bowl into the engine.
Check the power valves. They dump fuel straight down under the carb into the intake and not into the venturi like all the other fuel circuits.
My guess is that either a power valve gasket is leaking or the diaphram of the power valve itself is broken. Pop a new power valve into it and see if the leak stops.
Old Jul 21, 2003 | 07:18 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If it's leaking by the vaccum diaphram for the secondaries I would probably rule out the power valve since the Holley VS only have the 1 in the front metering block and nothing in the back. It would explain the flooding condition, but where is the leak coming from in the back?
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
TexasMaro
Sep 15, 2015 06:50 PM
WickedBowtie
Sep 11, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
