Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Pressures in each air bag?????
Old Jul 27, 2003 | 08:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Please click the link below to skim over my Camaro's specs. On Tuesday my air bags will be here and on Wednesday my shocks will arrive (Suymmit 3-way adjustable drag shocks - they are gonna be on the 50/50 setting), so Wednesday night I will be installing both of those. I know that the pressures in each of the air bags should be different and that I will have to play with the setup myself, but I would really appreciate some general rules about them. What should I start out with in each bag? Is there any difference I should maintain between the two (like always 10 psi apart or something like that)? Whats the minimum and maximum I should go? Mainly I am looking for some general rules of thumb as well as good information about them.
Thanks,
Brady
https://www.thirdgen.org/rides/index...ew&rideid=8390
Old Jul 27, 2003 | 09:37 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Good lord lots of things will play into this mix, so as you said it's gonna take some play, a good place to start would be 2-3 pounds in the drivers side to make the bag keep composure and possibly 4-6 to start in the pass. side and see how it likes it. Really no rule of thumb that I know of, just plain trial and error to see what it takes to get a even launch.
Old Jul 27, 2003 | 09:54 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Pressures in each air bag?????
Thanks,
Brady
Why would you want two? You only need one on the right side to preload the right rear. Use 20-30#
Old Jul 27, 2003 | 09:58 PM
Re: Re: Pressures in each air bag?????
Two are on the way, and two are gonna get installed - what can i say.
Old Jul 27, 2003 | 10:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
20-30 is way too much. When I still used 2 air bags I had the passenger side up to 25 psi for a while. When I finally pulled it out, the bag was extremely stretched out. That bag now sits on the shelf and I put the driver's side bag on the passenger side.
The most you should have to put in the passenger side bag is 15 psi. If you also use a drivers side bag, start with 5 psi in that one.
It's a tuning aid so air pressures will vary from car to car. I normally try to keep 10 psi in the passenger side bag.
This is all assuming you're using the standard Airlift red plastic air bags. I'm not aware of any other kits available for third gens.
Old Jul 27, 2003 | 11:02 PM
Thanks for the advice guys. I know I will have to play with it, and I guess Friday's TNT will help me with that. I am going to take Stephen's advice and start out with 5psi in the driver's side bag and somewhere around 12psi probably in the passenger's side bag.
Stephen, I purchased the Air Lift kit for 82-98 Camaros, part number 60897. Any advice on where/how to run the lines?
Thanks,
Brady
Old Jul 28, 2003 | 06:52 AM
AlkyIROC's Avatar
Car: 87 IROC L98
I ran mine through the frame rails and mounted the fill valves in the rear bumper. An ultimate setup would have a low pressure gauge(s) visable somewhere so you could see at a glance what the air pressure is.
Old Jul 28, 2003 | 09:51 PM
Yes, I was thinking about that when I ordered them, and also when I posted this. I don't know how you would do this though.....
Old Jul 29, 2003 | 12:53 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
where did you get the air bag???? i need 1 also
mike
Old Jul 29, 2003 | 03:09 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
im buying mine tonight along with a couple other things. summit sells them as a pair, and so does jegs. thunderracing.com is the only place i know of that sells just 1. the part # is AIR-60797 at summit.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
wild1
Aug 27, 2015 09:01 AM
jackhammer
Aug 15, 2015 10:04 PM
