Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Mixing fuel
Old Aug 29, 2003 | 05:49 PM
84zeddd's Avatar
Mixing fuel
A friend of mine has built a 10.75:1 408W.(I know it`s a ford).He
has been having a problem with pre-ignition.I don`t think there is any problem in mixing 114 octane race fuel and 94 unleaded.(if
you dont have cats) is there?
Old Aug 29, 2003 | 08:39 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: Mixing fuel
nope, you can mix fuel like that without any problems
Old Aug 29, 2003 | 11:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I can't remember the proper word for the chemical property of fuel but all gasoline can be mixed. Leaded fuel will plug up a cat and kill an O2 sensor if installed.
Mixing equal parts of both those fuels will give an octane rating of 104. 10.75:1 compression ratio shouldn't need more than 93. If the engine is knocking, I'd check other things first before increasing the octane levels. Cam and ignition timing would be the first place to look. Total timing might not be correct.
92camaroJoe
Jul 29, 2023 07:57 PM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
anesthes
Aug 8, 2015 09:37 PM
MENINBLK
Aug 5, 2015 11:58 PM
