Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
M/T ET Streets
Old Sep 26, 2003 | 02:30 PM
smithtc's Avatar
M/T ET Streets
May take the easy way out and just bolt on some ET Streets. What do ya'll think I should set tire pressure at? Start higher and gradually decrease tire pressure for each run, or start relatively low and increase?
Thanks,
TC
Old Sep 26, 2003 | 02:49 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
I'd start at about 14 psi and they should hook, if not then go a bit lower 12 psi 11... etc. hope this help and made sense
Old Sep 26, 2003 | 06:30 PM
88 IROC BOB's Avatar
What size streets are you using. I don't think you'll need to run them that low.
My car sounds very similar to your times. I run the 26x11.5x16 and use 20 psi. They hook great even with that much air.
Bob
Old Sep 26, 2003 | 08:55 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
I run 12.5 lbs but I'm a tad faster than you guys
Old Sep 26, 2003 | 09:03 PM
smithtc's Avatar
I think they are 28 diameter tires on 15" wheels.
What about driving to the track, if I choose,...what psi for normal driving?
Old Sep 26, 2003 | 09:05 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
20 PSI is fine....I drove on mine all summer like that and they should last at least through next season.
Old Sep 26, 2003 | 09:09 PM
smithtc's Avatar
Good deal, thanks fellas...
Must not be many cops in your parts pulling you over.
Old Sep 26, 2003 | 09:43 PM
AllGoNoShow's Avatar
ET Streets are DOT legal so the cops really couldn't give you any lip about it as long as the "tread" and I use that term losely, is still there.
Old Sep 26, 2003 | 09:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
more like
must not be many freak summer rain storms where you are.
Old Sep 26, 2003 | 10:17 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Originally posted by MrDude_1
more like
I have weather channel......
Old Sep 26, 2003 | 10:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
in the car?!
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Doobie52
Sep 11, 2015 06:19 PM
buckshot63
Sep 10, 2015 09:15 AM
