Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Need traction help. My cars spins wildly into 3rd gear.
Old Oct 15, 2003 | 12:49 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I seriously need some traction tips for my firebird, something low cost and effectly that won't add a lot of weight, not interested in heavy traction bars, or that kinda stuff. Here's what I have now...........home made control arm lowering brackets, lakewood boxed control arms, 3.73 stock posi 10 bolt rear, Jamex lowering springs, Yokohoma YZ 245/50/16 tires. The motor is a fairly stout 350 in the 450-475HP range and the transmission is a T-5. Since I dropped the new motor in, I wouldn't even feel confident racing high 12 second cars, even though Iknow the motor is good for high 11s (my buddies 11.80 chevelle runs the same motor setup with a heavier car) because of the massive traction problems I have. Any ideas?
Old Oct 15, 2003 | 07:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Get rid of those street tires and buy some slicks
Old Oct 15, 2003 | 11:30 AM
C-ya pony's Avatar
Car: 91 z28
Engine: 408,t-ram,twisted wedge aluminum heads
traction problems
i would just start with some bfg drag radials, i recently bought a set for my 91 z28. On regular tires my car wich makes about the same power as yours ran 13.40's & .50's with 0 to 60mph in the 4.9 to 5.2 sec range. Now it runs 12.70 to 12.90 and 0 to 60mph in the 4.2 to 4.3 sec range. Oh and i'm at 4000 ft elevation. Try em you'll like em also try a right rear air bag.
Old Oct 15, 2003 | 11:32 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
since i see some suspension upgrades.. here what i would add SFC's , a good torque arm and solid panhard rod. those will prob get ya better traction. what the 60 times??
Old Oct 15, 2003 | 11:40 AM
88 IROC BOB's Avatar
Mickey Thompson ET STreets-- worth their weight in gold!!
Bob
Old Oct 15, 2003 | 11:46 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
ET-Streets 26X11.5X16 should do the trick.
Old Oct 15, 2003 | 06:25 PM
rjmcgee's Avatar
Your T5 probably won't appreciate slicks. I kinda have a simular problem, how far can you push the tranny.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
reiderz iroc
Aug 13, 2015 04:57 PM
mizz0313
Aug 12, 2015 06:45 AM
92projectcamaro
Aug 6, 2015 01:20 PM
