Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
solid roller....
Old Oct 20, 2003 | 06:49 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: Moser 12 bolt, 4.11's 33 spline axl
solid roller....
this winter i want to switch to a solid roller cam.....
i was wondering what if any experiences you guys have had trying to figure out pushrod lengths???
Old Oct 21, 2003 | 07:46 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
From all the reasearch I've been doing, it's gonna depend alot on your particular set-up, you can get the plastic rocker arm and adjustable pushrod for around $25 this way you know exactly what you gotta have. Did you have your heads set-up for this soild roller, or are ya gonna install new springs for the added seat pressure needed?
Old Oct 21, 2003 | 08:56 AM
Car: '91 Camaro RS
im gonna change the springs....the motor is already built and running for 2 years, im just swapping from a hydraulic cam to a solid roller,
so all i really need to is the adjustable push rod....i was just curious as to what kind of luck people had using them, and how difficult it was to get an accurate measurement
Old Oct 21, 2003 | 09:37 AM
IHI's Avatar
IHI
Hopefully ya get some feed back, the new mill I'm building will be mechanical roller too so I'm interested myself. Still think I'll buy the tools since my geometry might be different than other fellas. Seen your runnin AFR's, how do you like them, I'm about 3 days away from ordering my 195 AFR's, think I'm jsut gonna order the plain set and take them to the head guy here and let him work 'em over, I can get quite a bit of things done for the difference of the street head and race head.
Old Oct 21, 2003 | 12:40 PM
Car: '91 Camaro RS
the heads are amazing, as long as you get the right sized heads for your application you'll be very pleased
Old Oct 21, 2003 | 12:49 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Hey bud,
We used the comp cams adjustable to get the valve train geometry correct on the new 383. One of the advantages to this type of pushrod checker is that you can put it in with your real rocker, set lash, etc. and then measure.
Solid will be wicked nasty in that thing. Good luck.
-Schultzy
Old Oct 21, 2003 | 02:09 PM
Car: '91 Camaro RS
Originally posted by Schultzy89GTA
Hey bud,
-Schultzy
thanks man, should be a fun project...
how do you tighten the rocker down to obtain the measurement??? im assuming you need to get that set up before you can measure with pushrod checker....
i've never needed special push rods before
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sammy52401
Nov 11, 2015 07:20 PM
loud91rs
Oct 5, 2015 10:05 PM
kkirch15
Sep 30, 2015 04:44 PM
dusterbd
Sep 29, 2015 08:40 AM
