Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What do you guys think, predictions
Old Mar 2, 2004 | 12:39 AM
christian's Avatar
My new motor is fully machined and balanced. It is a 355 sbc with a forged gm crank, eagle H beam rods and TRW forged pistons. The compression ratio is 12 to 1. I'll be running a solid crane nitrous grind cam with 114 lobe seperation 500 520 lift 248 258 duration at .50. I will be running AFR 210 heads, using a vic junior intake and a 650 double pumper carb with a proform main body.
I will be running a 250 shot with the edelbrock rpm kit.
Last year I ran a 11.25 @ 122 on a 150 shot and that was with a much milder motor and TFS 23 degree heads.
What do you guys think I might run?
A friend of mine has almost the identical motor with the only exception being the camshaft and carb and with a 250 shot with the edelbrock rpm kit he ran 10.07 last year.
I don't expect to go that fast but perhaps mid tens? BUt I really don't know?
Old Mar 3, 2004 | 11:32 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: What do you guys think, predictions
That thing is going to want to spin some RPM. I am going to say that your car could run as well as 11.5's with a larger converter N/A (which may not be optimal for nitrous) and probably down close to 10 flat on the bottle. Who knows, it may break into the 9's .
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
