Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
'94 Z28 with mods
Old Mar 12, 2004 | 02:16 PM
IROC_Vert's Avatar
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
'94 Z28 with mods
Hey everyone,
what are your opinions on the following setup, what times do you think it will be capable of running in the 1/4 ??
It's a '94 Z28 with M6 and the following mods.....Borla cat-back exhaust w/ Hi-Flow cat, Moroso cold air, B&M Ripper, BMR adjustable panhard rod, BMR LCAs w/ bolt-on adjustable LCA brackets, Thunder Racing brake package w/ PowerSlot rotors, Hawk pads, and stainless steel brake lines...and some others....
Alex
Old Mar 12, 2004 | 02:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Are you planning on racing him. If not this is gonna get locked. If you are going to race him you better run better than mid 13's.
Old Mar 12, 2004 | 02:45 PM
Mad-Mic's Avatar
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
the 94 will run mid 13's maybe worse of 13.7 best 13.4 if he knows how to drive.
Old Mar 13, 2004 | 03:18 PM
MdFormula350's Avatar
mid to low 13s like Mic said. if drag radials most likely low.
Old Mar 13, 2004 | 06:59 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
my GFs 94' Formula has almost the EXACT same setup. it runs 13.24 at 103.97mph... with an auto! if this guy can drive stick, and especially with that short throw shifter, expect better than that
camaro1185
Oct 26, 2015 06:51 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
R13_Braz
Sep 18, 2015 05:00 PM
