SCCA - autocrossing
Car: 1986 IROC-Z
Engine: 305 T.P.I.
SCCA - autocrossing
dose anyone know SCCA rules for wheels???
what i mean is i whant to go with 18 inch ZO6 rims, but i need some mother f*cken adapters. so would i be able to race with the adapters on???
also does anyone know how the adapters will efect the cars handleing abilites? if so is it fixable???
THANKS
THANKS
Car: 1982 Z28
Engine: LC9
Transmission: AR5
You can't run 18" wheels in stock but it's OK for SP, SM ... there may be some limits in CP and the other Mod classes.
This is a good website for the Stock, Street Prepared/Touring/Modified rules:
http://www.moutons.org/sccasolo/
Pat
Pat
Car: 1986 IROC-Z
Engine: 305 T.P.I.
that link helps alot thanks.
i don't care about the class i'm in, i what to race for fun... besides i'm into drag raceing more. i just whanted to see if i could run with the adapters on.
Car: 85 IROCZ
Engine: L98 355 ci
auto crossing
I autocross an 85 IROC with ZR1 9.5 and 11.00. Have adapters. One can run ESP, SM, others I'm sure. Handles great, and makes a big difference in times. SPD performance for adapters. 2.25 front and 1.25 in the rear with 11.00 wheels.
Good luck
Good luck
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you should be fine with adaptors, the other thing you can do, is if you go , sign up to just do a 'fun run' most places will let you do that, you won't be competing in a class, or for points, but if you just want to go drive the snot out of your ride, that might be your bag.
