Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Short Spark Plugs
Old Jun 6, 2004 | 07:12 AM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
Short Spark Plugs
Who makes the shortest spark plugs. Presently I am using Accell header plugs. They do not have the selection of heat ranges that I would like.
I have a couple of really tight areas caused by using Pro Topline heads and Hedman LT headers.
Old Jun 6, 2004 | 08:16 AM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
Not sure if these are the shortest ones but I've had good clearance with Autolite race plugs with different sets of headers.
Old Jun 7, 2004 | 11:52 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Short Spark Plugs
What is the recommended plug for these heads by Proline? I need specs on Thread reach, Thread dia ( probably 14mm ) and whether they have taper or gasket type seats. I have a Master NGK catalog that might have something of interest but need to know a baseline plug to cross reference. Accel CRef not in catalog.
Old Jun 8, 2004 | 12:07 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Is THIS short enough?
PS: Don't think it will work..probably too cold...and freakin' expensive!! But it's dammned short. 14mm x .750" gasket seat with 5\8" hex.
Old Jun 8, 2004 | 03:50 PM
muggsyjack's Avatar
That would be short enough...... threads look too long though. Seriously, need to match AC R-43T or R-42T for later small chevy. The current Accell header plugs are on hot side for heat range and are extended tip. Would like to have more options. The Topline staight plug heads are hard to get plugs short enough for. Boots get to close to pipe.
I'll check actual thread spec.
I tried the original plugs from 305 to verify tip in chamber and they fit fine till I tried installing them after headers were bolted on. Mad dash to parts store for header plugs. Had to take what they had. Hotter than I like and expensive.
Old Jun 8, 2004 | 09:57 PM
muggsyjack's Avatar
Using Accell #574S shorty plugs.... 14mm taper seat, .460" reach 5/8 hex. They are a little warmer than I like. Also are projected tip, would rather have regular tip.
Other reference numbers are AC R43TS, R45TS.
Old Jun 10, 2004 | 11:54 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Stop chasing plugs and get some fiberglass spark plug boot cover things. They aren't cheap, but they work. You can get them at napa for like $15-8 for a set of 2.
Old Jun 10, 2004 | 03:35 PM
muggsyjack's Avatar
Need more than boot covers...cannot get AC or Autolite to even start threads...it is that tight.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
