Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
G-tec Pro?
Old Sep 14, 2004 | 07:56 PM
1bad92TA's Avatar
Car: 1992 Pontiac Firebird
Engine: Lo3 305
Transmission: th700-r4
Axle/Gears: stockers
G-tec Pro?
Ok i just used a G-tech Pro to measure my cars 1/4 mi time and Hp/Tq and i was a little disappointed . But my question is "Does the weight that you put in for vehicle weight matter a whole lot?" I put in 3500lbs. I know my car weights a lot more ( like 4200lbs.) but I think it would make a differnce, right? Well just looking for some input thanks!
Old Sep 14, 2004 | 10:34 PM
MdFormula350's Avatar
a stockish thirdgen is around 3,300 to 3,500 w/o driver.
so u guessed right.
Old Sep 15, 2004 | 07:54 PM
1bad92TA's Avatar
Engine: Lo3 305
yeah but it gave me 119Hp/ 129tq! That is insulting to any v8 if you ask me . I have an LO3 that was rated at 170Hp/255Tq and it is hard to believe that 114,000 miles will drop the numbers that mutch plus I put a full exhaust, ultimate TBI mod, and removed the smog pump. I'm baffled
Old Sep 15, 2004 | 08:09 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yeah but the G-tech are measuring your actual performance at the ground and the factory ratings are at the motor. There off a little bit too.
Then you got figure in the G-tech measures off the line horsepower when any other chassis dyno would run your car into a 1:1 ratio on the transmission then pound it. So you got to account a little bit for wheel spin, roll in hesitation (if any), and just the accuracy of them.
My G-tech was telling me I was making around 230 HP or so and the dyno said 211. There fairly close and there decent to use as testing and tuning tools. Anymore I only really use mine for 0-60 mph time... maybe 1/4 mile if I want to stay on the gas.
Old Sep 15, 2004 | 09:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Garbage in, garbage out. It needs to know the total weight of the vehicle with driver, fuel stereo etc since it does calculations based on accelleration with weight. Giving an incorrect weight will give an incorrect HP/ET etc.
Old Sep 15, 2004 | 09:37 PM
Engine: 383 SBC
Yeah but you got to admit the 0-60 and 1/4 mile would be nice things for tuning since they don't have any weight settings on them. That way you can compare the times to the G-tech's previous runs... it seems to be pretty consistent. Just gotta make sure you level it out each time properly.
Old Sep 16, 2004 | 10:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
I have a '91 gta 305 tpi. My weight with my stereo, spare tire and me in it was 3690.
Make sure that you are inputting that number into your g-tech other wise it scews the figures. I have the same gtech.
Also, remember that for every 100lbs, it is a tenth of a second in the 1/4 mile(roughly 10 hp).
Old Sep 18, 2004 | 09:29 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
so the Gtech gives the hp att the wheels, and not the motor?
so with a automatic trans. i can add 20%?
example: Gtech (i got the cheap version) gives a 160 hp, so thats 192hp the engine delivers.
right?
Old Sep 19, 2004 | 12:32 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Yes, rear wheel hp. But it depends on traction.
So yeah,20% .
LB9GTA
Old Sep 19, 2004 | 12:45 AM
AlkyIROC's Avatar
Car: 87 IROC L98
20% is only a rough guess. Different transmissions and differentials give different hp losses. Swapping transmissions can decrease the hp loss without touching the engine.
Lets say your engine produces 200 hp and you guess at a 20% loss giving you 160 hp which is a loss of 40 hp. My 600 hp engine with your powertrain loss of 20% means I only have 480 hp losing 120 hp through the same powertrain instead of 40 hp.
That's why a percentage loss is only a rough estimate and shouldn't be used to calculate engine hp from RWHP.
tmellott89
Oct 14, 2015 02:06 PM
Pinguiclia
Oct 12, 2015 04:47 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
jbates346
Sep 22, 2015 05:22 AM
