Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
who's running 12.0s
Old Nov 25, 2004 | 01:51 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
who's running 12.0s
Who's running 12.0's to 12.30's with what setups?
Old Nov 25, 2004 | 07:02 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I had one a combo in my car at one time it ran best in cold weather 11.89 but most of the time it would run 12.10s to low 20s It was a 355 with stock cast crank, and x rods with arp rod bolts, trw 2256 forged flattops 0 decked, world products 200cc heads, a comp cams 294s cam, roller rockers,old edelbock torker intake,650cfm carb,hooker long tubes,and dual 3in exhaust. Same motor with cheater plate and a 175hp shot ran 10.80 @125 mph. On street tires and on pump gas.
Old Nov 26, 2004 | 02:03 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Best pass on radials is 12.28 @ 111.XX
Setup:
350HO crate engine:
XE274 hydraulic flat tappet camshaft
Shaved Heads to 57 cc, .015 Fel Pro head gaskets (9.9:1 compression)
Ported/polished Vortecs
Proform 1.5 self alligning roller rockers
Cheap K-motion valve springs
Hedman 1 5/8" shorties, dual 2 1/2" w/ X pipe and bullets
Drivetrain:
Hughes Pro Street 3000 stall
7.5" 10 bolt, 28 spline axles, richmond 3.73 gears, SLP $99 take off posi
275/50/15 BFG Radial T/A tires
Car is a 1982 Camaro, race weight is close to 3300 pounds w/ driver, 3075 w/ out.
Old Nov 26, 2004 | 08:17 PM
Engine: LB9/383
Thanks guys.
Unknown: I'm guessing you're carbed? What carb/intake are you running?
Old Nov 26, 2004 | 08:28 PM
Originally posted by NastyL98_T/A
Thanks guys.
Yes I am carbed, running an Edelbrock Victor for vortecs and a Speed Demon 750 mech secondary carb.
Old Nov 27, 2004 | 08:42 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
My current combo has ran an 11.7@116mph after cam swap and head porting. My orignal 383 combo ran a 12.02@113mph with a smaller cam and unported dart pro 1's everything else is the same as in my signature. Cam was a bullit hyd roller 225/230 dur@.05 .525 lift...great cam for street/strip. Normally that setup ran 12.1-12.3 depending on weather.
Old Nov 27, 2004 | 11:49 AM
Engine: LB9/383
Thanks guys. I'm looking for the hot setups to get me into the low 12's but stay above 12.0 so I can stay in the street class at my local track. Putting together a 4 bolt 355, stock crank, eagle rods, TRW pistons, AFR 195 heads w/64cc chambers and I've got a super ram but I'm thinking about going carbed
Old Nov 27, 2004 | 08:06 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
If you have a late model hyd roller block I have the specks for a geat hyd roller that works with the factory lifters and retainers. I put this combo together fo a buddy he wanted a motor he coulde drive and take on long tips and use ac and soforth. On a stock short block dish pistons and the afr 195 heads and 650 cfm carb it ran 11.80 at 115mph you can alway detune or dare I say it lift at the big end.
Old Nov 28, 2004 | 09:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
with superram and a 10.5 to 1 or higher 355, and with LPE 219 cam, you should be low low 12's. slightly ported out AFR's and SuperRam with slightly bigger cam like 224/224 or 224/230 duration and .550lift, you should be 12.0's or so with good launches.
Old Dec 1, 2004 | 10:24 PM
primo's Avatar
I have a 383 superram, AFR 190, 30# injectors. Running 12.3 @ 110 mph. Chips by me.
Old Dec 1, 2004 | 10:46 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Im close with probably the least mods...
Stock bottem end, stock cam, stock heads (GT-40 valves, but NO porting at all), Cobra intake (unported), 65mm TB, 75mm MAF, CAI, Headers, H, and catback, 3.73s, T5 with FMS clutch, shifter, stock suspension, and on slicks ran 12.56!
Maybe some suspension and Id be there!
Old Dec 1, 2004 | 11:32 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
ur doing 12s the way it should be done! i hope to be there when my car is back on the road
Old Dec 2, 2004 | 02:27 AM
Whats your car weigh?
Old Dec 2, 2004 | 04:42 PM
Marc 85Z28's Avatar
That's nice... but I believe he was referring to SBC setups
I've run a best of 12.92@107 on the combo in the sig. I've got World Products S/R heads, cleaned up and gasket/port matched. Cam recently wiped a lobe, and I've now got the Jasper piece back in
Old Dec 3, 2004 | 04:46 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
I ran 12.1@111 on a 1.69 with this setup
Stock turbo, intercooler, injectors, down pipe, cat back, suspension, torque converter.
Mods were:
8" K&N, ATR intake pipe, 92 Thrasher chip, 160 thermo, 210/205 cam, cat pipe, valve cover breather, adjustable fuel pressure regulator, and Nitto's.
Not too shabby for a V6 Of course that might not help too much
Old Feb 7, 2005 | 06:16 AM
JOHNNY383's Avatar
Car: 87 T/A
Engine: 383 TPI
12 o's.....
http://www.highperformancepontiac.co...0106hpp_event/
'87 T/A
J383.
Old Feb 7, 2005 | 12:09 PM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
He didnt specify...
Also the car weighs between 3150 and 3200 lbs!
Old Feb 7, 2005 | 12:19 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
My trans am will pull a 13.4-.5 on slicks. Course I need to go buy some first...
I'm sure I'd get in the 12's with a little N20. Or some bolt-ons lol.
Old Feb 7, 2005 | 03:26 PM
He didnt specify...
Curb weight or race weight?
Old Feb 7, 2005 | 06:05 PM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Race weight!
Old Feb 7, 2005 | 06:27 PM
Race weight!
Ok we are settled then . What are you doing for next season?
Old Feb 23, 2005 | 06:18 PM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
12.08 on a 1.68 IIRC. nominally I do 12.200 I have that 12.08 run on video oddly enough... but I lost to a 350 Iroc (Hi Trax!)
406/(lig)SR/T56/HOTcam. car is set up for roadracing but still pulls a fair 1/4. much more power to be had with simple cam upgrade but I like it the way it is for RR.
video:
http://www.eecis.udel.edu/~dzug/indy...teVette-II.wmv
COME TO OUR EVENT! URL at end of video.
Old Feb 23, 2005 | 08:17 PM
Engine: LB9/383
Wow, this thread was brought back from the dead, lol. I've got the motor together now, changed plans bigtime since I started the thread. Sold the SR intake and went with a 650DP and a Performer RPM intake, Eagle 383 crank with 400 rods and forged pistons.Kept the AFR heads, stock. Mild cam. It's sitting on the engine dyno at work now and the first pull it made 465hp. Plan on getting it dialed in by the weekend.
Old Feb 23, 2005 | 08:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Good numbers. That ought to get you in the low 12's without any problem. I notice that most of the motors were 383's or larger. Allen
Old Mar 12, 2005 | 01:08 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Im running mid 12's consistantly on stock motor (internally) and trans with a 150 shot of spray. i got some steep gears though (4.10's) i got my complete build history from stock on my site pg.3
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
