Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
SFC and Rollcage
Old Nov 26, 2004 | 04:48 PM
Mentor58's Avatar
SFC and Rollcage
Hey Gang,
Gotta question for you all, I'm lookning at doing an 83 totally for the strip, and I'll be putting an 8 point cage into it. (actually, I'll be having a local chassis builder for the roundy-round guys put it in, since I don't trust my welding for something like that) . Do you feel that with the full cage that SFC's are needed, wouldn't hurt, or just be a waste of money?. It's not that I'm cheap, but I don't want to spend money on an upgrade that isn't really going to provide a good "Cost-Benefit" ratio.
TIA,
Steve
Old Nov 26, 2004 | 05:07 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Yes put sub frame conn in. I like the south side machines my self for the simple fact you can also weld the main hoop and front down bars to them.
Old Nov 26, 2004 | 06:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need both. The roll bar/cage doesn't attach to the chassis but is only welded to 6" x 6" plates that are welded to the sheetmetal floor. The SFC tie the front and rear "subframe", if you could actually call it that on a third gen, together.
Old Nov 26, 2004 | 06:59 PM
Mentor58's Avatar
Thanks for that nice clear concise explanation. Now that I think about it, it makes a lot of sense. Might as well do it right the first time
smw
Old Nov 26, 2004 | 10:19 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
If you go with a cage like the Competition Engineering two of the points actually tie into the SFC's.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
Hill1513
Sep 19, 2015 04:15 PM
TexasMaro
Sep 15, 2015 06:50 PM
luvofjah
Sep 10, 2015 10:41 AM
