Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
what can i expect???
Old Jan 23, 2005 | 10:10 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
my new mods are in my sign guys what can i expect maybe a 13sec 305 fbody car???
Old Jan 23, 2005 | 10:48 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
You can expect that carb to be to much air for that motor, go with a 600
Old Jan 23, 2005 | 11:13 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
14.0 - 14.5..... if you're good.
Old Feb 4, 2005 | 11:04 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
so all the mods were done to the new engine u didnt have any of those on the old tbi. if so all you really added was the manifold carb cam the porting to your heads wasnt really worth the money imo the carb is to big and the rest of the stuff is basically tuneup things to make it run its best not add hp. the gears were they in there be4 if so then id say 14s not 13s yet at least not mid 13s
Old Feb 16, 2005 | 10:06 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
im still curious to this because it ran a 14.56 with bone stock internals and TBI
Old Feb 17, 2005 | 12:26 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Ditch the DP.
Old Feb 18, 2005 | 10:35 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
i think you have a really good shot at 13's. Look at mw66nova's car he is running 13.7's and his cam is smaller and he dosent have the stall, he does have it bored over .030 though. I would say you could get into the 13's with that if you can hook but there is only one way to find out. And they're right about the carb thats way to much go with a 600 cfm. Also ditch the flowtech headers they are crap and they will cost you time.
Old Feb 19, 2005 | 05:49 AM
TTA-Matt's Avatar
Car: 89 Turbo Trans Am Pace Car
Engine: 3800 turbo
i know stock tbi's that run high 15's, they arent fast. how did you manage the 14,56?
i don't think you can run 13's with this setup. i run 13's with my stock tta!
matt
Old Feb 19, 2005 | 07:51 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
That's WAY too much carb for your 305. 600cfm is more than sufficient for a modded 305.
Old Feb 19, 2005 | 04:24 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
get the 4150 version of the 600cfm vaccum sec. carb. that is what i am running. 13.75@100.5 with a stock converter from an l98 corvette. 1800stall roughly. 2.02 60' with traction, stall is too low. getting built 700r4 with tax return. already purchased new converter from ATI built for my motor and gears. getting new m/t drag radials too for more traction, cause BFG's ae now toast. with weight reduction (3045lbs no driver, 3300 w/) and new tranny/converter/tires, i should see some low 13 sec. passes.
www.cardomain.com/id/mw66nova for specs on motor.
Old Feb 19, 2005 | 11:11 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ok thnx a million guys i have a guy thats says he will trade me a 650 vacuum secondary for my 750
i didnt pay anything for the 750 its and old carb i had off of my old mans stroker motor that ran 11.8s
would a 650 be too much as well??
Old Feb 19, 2005 | 11:40 PM
mw66nova's Avatar
Engine: 7.0L
650 is better. may still be a slight pain to tune.
Old Feb 20, 2005 | 03:12 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
since it's a dual plane intake each side of the motor is only going to see half that CFM. now if you were running a single plane intake i would definately recommend a smaller carb, but on a dual plane i would keep it on there IMO. if it works well i wouldn't mess with it since the price was right. I am running a 750 VS carb on my 305, which the secondaries won't open all the way due to the way a VS carb works on sizing towards airflow requirements, but with your 3500 stall converter I don't see there being much of a flat spot down low either that is usually caused by too much carb. If there's no bog and gas mileage isn't too bad I wouldn't worry much about it.
Old Feb 20, 2005 | 08:34 AM
mw66nova's Avatar
Engine: 7.0L
xpndbl: he is running a double pumper though.
Old Feb 20, 2005 | 01:21 PM
V6camaroman's Avatar
just a wild guess i put you at a 13.6 at 102mph with traction. you had a good respectable time with the tbi. 14's out of a 305tbi is great.
Old Feb 20, 2005 | 04:51 PM
mw66nova's Avatar
Engine: 7.0L
take it to the track, run it with the big carb and see what she runs, come back, slap other carb on, run again. it's the only way to tell really, but i still think you are over carbed.
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
