Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
3 mph needed
Old Mar 26, 2005 | 12:18 AM
  #51
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally posted by Chickenman35
What do you want the 2-3 shift to do?
I want it to happen at WOT. At WOT, the tranny will shift manually fine, or at 4800 RPMs 1-2 by itself (gearshift in 2nd, D, or OD), but if at WOT, 2-3 will never occur.
Old Mar 26, 2005 | 12:27 AM
  #52
five7kid's Avatar
Originally posted by blacksheep-1
IMO offload the transgo stuff.
http://www.turboaction.com/
Don't see anything for TH700's.
Old Mar 26, 2005 | 02:53 AM
  #53
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Well...that's not right obviously. I could go through my Transgo notes ( spent quite a bit of time setting up various 700R4's ) but have you tried calling Trango's Tech line? I've found them to be very knowlegable.
To me it sounds like you need heavier governor weights. That would be my first bet. What governor is in there? I ended up using a Diesel governor to get the shift points I needed.
Rear end gear ratio changes really mess up Governors. As do taller tires etc etc. That is why what works on one car may not work on another. Any " shift kit" by ANY mfg is baselined for stock gearing and stock size tires. Change either ( wheels or gearing ) or worse yet...BOTH... and governor calibration goes out the window. Since the governor affects nearly every single circuit in the transmission, you can see how steeper gears or taller tires can really mess up the shift points.
What other things to alter shift point have you tried? Separator hole plays sizing also plays a big part in tuning. As does valve body spring selection. It can all get very complicated. It doesn't help that one change seems to affect three other things. Oyyy Vayyy
Do you have a Type 1 valve body or Type 2? I can look up some info...but need to know what valve body type you have. Type 2's have an Auxilary Valve body, usually 1987\1988 and later.
BTW...most professional shops consider Transgo to be one of, if not "the " best Product line on the market. I've dealt with many different Automotive Transmission suppliers and know quite a few people who build Auto's for a living. These are guys I know and trust. They all consider Transgo to be an A-1 product.
The kits are not for the " average" consumer though. They are more complicated than the average " shift kit" and are really meant for advanced or Professional builders. One thing you ABSOLUTELY cannot do with a Transgo kit is take " shortcuts" in the installation. Everything must be done exactly as per the instructions, as a Trango kit ( especiially the " Street\Strip " or " Race " mods ) change many more items than the Typical " Brute Force and Ignorance " kits such as B&M.
With a little tweaking, there is no reason whatsever that you cannot get that tranny shifting exactly where you want it. I'd definately give Transgo a call though if you haven't already.
Old Mar 26, 2005 | 03:05 AM
  #54
Car: 86\92 Mutant
Engine: 355CI 430HP
One obvious thing...is TV cable adjustment correct? A more accurate adjsutment can be made by rotating the throttle by hand to WOT to set the adjustment, rather than just mashing the throttle to the floor. A couple of "clicks" on the TV cable can make a considerable differance.
If shift point is to high or you get a " No shift " at WOT, move the inner sleeve a bit closer to the carb. This is a quick fix, and you don't want to stray too far from the " correct" baseline.....but this will often correct a problem with a shift point that is just a bit too high. Can be used for fine tuning of shift points as well, once you're " in the ball park".
Old Mar 27, 2005 | 03:13 PM
  #55
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
What about experimenting with other (people's) parts. If you are just playing around on a test say and ET isn't important, try some shorter tires to build rpms. I didn't see what intake you are running but if a buddy has something to try, that's an easy swap. So is trying a bigger carb. Just a few ideas...
Trevor
Old Mar 27, 2005 | 10:43 PM
  #56
five7kid's Avatar
The TH700 is an '86, w/o the aux. Dana of Probuilt went through the setup with me (a lot of time spent on the phone). Nothing helped. TV cable is absolutely adjusted correctly. Since I went w/o TC lockup for a couple of years, I probably hurt the 3-4 pack. I have 2 other TH700's to try to get it to work. The guy who rebuilt the TH400 for me said to bring the front pump by, he has some 13-vane units he'll put in for me.
I'm thinking street tires might produce a higher MPH than the slicks. Since ET won't be the issue, getting off the line won't matter. But, rolling resistance might.
I'll have to ask around to see if anyone has a Stealth or RPM manifold I could borrow for the 396. Or, even a single plane. Right now I'm running an Action +. I doubt a larger carb would help any.
As for the frontal area, I was brainstorming with the co-worker who went out to Pomona with me. Thought I'd take the panels on each side of the radiator out, then open up the heater and vent openings in the firewall, and adjust the trunk lid so it has a gap. That would allow the air to go straight through the car (with the back seat out).
I'll probably do all this and end up with a 99.8 mph slip, or something like that...
Old Mar 27, 2005 | 11:37 PM
  #57
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Is 97 your best MPH or the MPH on your best ET. What is your usual MPH on a normal weather day?
Old Mar 29, 2005 | 10:29 AM
  #58
five7kid's Avatar
The one in the sig was with the best ET. I believe there have been a few slightly higher than that, but no 98's.
"Normal" is low 97. It'll dip into the 96's when the weather gets hot or there's a headwind.
I haven't run the Camaro enough to get much data on it. I would suspect that I could make hefty gains with it with the 350 and a properly operating transmission.
Infested
May 22, 2018 11:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
