Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What trap speed do I need for a 7.70 pass (1/8th mile)?
Old Apr 12, 2005 | 09:20 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I know there's a bunch of different variables, but I'm shooting for a 1.65 or better 60'. I trapped at 84mph last time out and that was missing third every pass (clutch was done). Hopfully shooting for high 80's in the mph. Will that do it or will I need a low to mid 90mph pass to get that ET?
Old Apr 12, 2005 | 11:36 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I think my best was 7.88 @ 88.XX with slower short times than you are running, I would imagine with your short times you only need a few more mph.
Old Apr 12, 2005 | 08:17 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
My old car used to run in the 7.6-7.7 range (best 7.61@90.31mph on a 1.63 60ft) and speeds between 88-90mph.
HTH,
Steve
Old Apr 13, 2005 | 05:08 PM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
Should be 88 - 90 MPH. Since you are running a stick, may be a little different.
Attached Thumbnails What trap speed do I need for a 7.70 pass (1/8th mile)?-forest1tgo.jpg
Old Apr 15, 2005 | 10:59 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Are you just running air bags in the rear? No Anti-roll bar? Looks like it launches pretty straight.
Old Apr 15, 2005 | 11:19 AM
muggsyjack's Avatar
Boxed Lower control arms, relocation brackets, airbags, adjustable panhard bar, stock torque arm and stock rear sway bar.
Car does launch very flat. Use 10 to 15 PSI differential in bags.
This car is son's car, ran best of 6.88 in 1/8th mile w/1.44 60' time. Engine is .030 over 350 4 bolt spinning to 7500 RPM. Rear is 9" w/5.14 gears and 5700 stall converter.
Red car below is 4.30 rear gear car. Picture shows 350 power. With 305 currently in car, has run best of 8.01 at 83.5 MPH w/1.72 60'. This is through a TH-400 w/5400 stall converter.
Attached Thumbnails What trap speed do I need for a 7.70 pass (1/8th mile)?-img_1745stgo.jpg
colton_carlson
Mar 8, 2019 12:21 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
jbd1969
Aug 17, 2015 07:06 PM
kyleb24
Aug 15, 2015 08:24 AM
