Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New best time off the bottle
Old Apr 17, 2005 | 04:39 AM
EvilCartman's Avatar
Car: '82 Z28
Just got back from the drag strip a bit ago with a new best time for a motor run. Last year the best was a 13.42 @ 102 with a 1.91 60'. Tonight's first run was a 12.22 @ 111 with a 1.80 60'! The biggest change I've done since last September was to chop the single 3 inch exhaust off right at the end of the y-pipe Friday night. Also rejetted the carb and have an air pan sealed against the cowl hood. It just blew my mind how well it ran tonight, I thought maybe I'd get into the high 12's but not 12.22 It's finally starting to run what I had in mind when getting the motor together.
Edit, here's the video
Old Apr 17, 2005 | 06:37 AM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Thats awesome. Now try that 210 shot and see if you can't get a low 10.
Old Apr 17, 2005 | 09:33 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Very nice improvement. Do you have any pics of the pan you used to seal the carb to the cowl?
Old Apr 17, 2005 | 09:39 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
WOW! id suggest some lontubes and a true dual system now!
i like the NO TREADS rule. that is the single reason it's so hard to hook at my track. all the little imports drag water up to the starting line.
oh, looks like you may need to work on that reaction time a little bud.
Old Apr 17, 2005 | 10:01 AM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Wow, that was quite an improvment! I never wanted to SAY it, but EvilCartman I thought that for what you had in the motor and with 4.56 gears 13.42 N/A was pretty weak, and it was- but now we know why! Sounds like it was really corked up and you hit the problem on the nose! Some longtubes and true duals look like the ticket to me. I bet there's more N/A to be had there too.
Old Apr 17, 2005 | 11:01 AM
Car: '82 Z28
84firebird383, if I get a 10.9X sometime this year using the nitrous I'd be really happy Friend of mine said that it would get into the 10's and I didn't believe it would be possible till last night.
Blackroc86, I'll get a pic later today when the car is unloaded.
mw66nova, Exactly the plan for new exhaust Oh and my reaction times lol they've put in a new tree this year so I'm not used to it (really never been good anyway ) Had a red light my second run.
eric17422001, I've been disapointed with running mid 13's on the motor since the first time to the track with the 350. Knew something was up and had a hunch it was the exhaust hehe.
Thanks guys for the comments now for 11's on the motor
Old Apr 17, 2005 | 12:43 PM
mw66nova's Avatar
Engine: 7.0L
ever get a bar in the car??
Old Apr 17, 2005 | 05:25 PM
Marc 85Z28's Avatar
That's more like it!
So much for the Spintech being superior...
Old Apr 17, 2005 | 05:27 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Nice! Bring it up to Southern Oregon soon .
Old Apr 17, 2005 | 07:06 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Nice numbers
What were your trapping at the stripe? how tall of a tire are your running?
Only asking cuz if your up there already in rpm, when you hit the juice you might not have anyplace to go with it except Nascar style 9K
Old Apr 17, 2005 | 07:19 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yes, very good times. What is your exhaust from the Y-pipe back? Just wondering how restrictive it is. Allen
Old Apr 17, 2005 | 08:40 PM
mw66nova's Avatar
Engine: 7.0L
i believe he was running a single 3" pipe with a spintech muffler.
Old Apr 17, 2005 | 09:21 PM
Car: '82 Z28
Hehe, it's the crappy single 3 inch system that was holding me back. Going to see about getting the oval pipe setup with the low profile spintechs or do a big single, not sure yet till I start looking under the car.
I was turning about 6800 at the line running 26" tall tires. Probably have to step up to 28" tires and maybe some 4.10 gears.
Not yet, looks like I'll be spending some money getting one in now.
Old Apr 17, 2005 | 09:23 PM
Car: 1989 GTA
Engine: 369 TPI
I was just wondering as I ordered the 3.5 inch Mufflex system for my car. Thanks, Allen
Old Apr 17, 2005 | 09:51 PM
IHI's Avatar
IHI
I'll be interested to see how much the gear change/tire change affects ET/mph. Depending on your cam it may not change too awful much since it'll be using the torque factor from your cam to push you through the gears, but will really open up a window on the top side when you decide to spray.
Old Apr 17, 2005 | 10:04 PM
Car: '82 Z28
Just took a pic, nothing really fancy but it works Really need to get some aluminum bent up to hold the radiator. Those temporary brackets have been on there for some time now hehe. Oh, the big alt pulley is on because I was trying to fix a belt throwing issue. Finally got everything aligned right and no more problems
Old Apr 18, 2005 | 04:41 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
i have hookers headers#2055 and a cut right after the y pipe. i pick up about 1mph in the 1/8 with the cutout open.
bamaboy0323
Sep 3, 2015 06:07 AM
fonzie85
Aug 13, 2015 11:50 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
