Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
I think i found out whats wrong with my car
Old Aug 2, 2005 | 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i heard abit of a exhaust leak so i checked it out. Drivers side header
back cylinder.
I am missing one whole bolt!!! and the other one is looser than hell! could that give me a bit of a horsepower loss??
Old Aug 2, 2005 | 04:33 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Man, that header leak can suck alot of performance out of your car. Lucky find
Old Aug 2, 2005 | 06:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well i just put in a new bolt and tightend up/checked all the other ones. took it for a quick spin and it feels abit stronger. i'm thinking it might be back to normal but too early to tell. i need to get some more track numbers
Old Aug 2, 2005 | 06:36 PM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
I'm thinking it's the heat and humidity that's killing your power. My best trap at Thunder in the North was 98 MPH and everyone else was down 3-5. Hot lapping didn't help! I made 15 passes, all in the 13.9-14.0 range. I won't see decent numbers until Oct-Nov. Gotta love the cool dry air!
Old Aug 2, 2005 | 07:03 PM
Exactly, but I don't think a header leak will help performance.
Old Aug 2, 2005 | 07:05 PM
Blu91Z28's Avatar
Engine: TPI 5.7 L
Yeah, exhaust leaks don't help either!
Old Aug 2, 2005 | 10:28 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I dont see how they could hurt cause exhaust is be vented either way and its going to flow through the path of least resistance so....
Old Aug 2, 2005 | 11:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
a leak doesnt help scavenging which helps build torque IMO
Old Aug 3, 2005 | 12:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
and torque is why TPI cars run the times they do.
Old Aug 3, 2005 | 01:06 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
whats the best header gaskets for cast iron heads? are there any with a less chance of leaking?>
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i think copper is good.
Old Aug 3, 2005 | 11:57 AM
phoenix305's Avatar
yeah but copper gaskets cost like 50$.
Old Aug 3, 2005 | 01:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i heard the cheap paper like gaskets that usually come with headers, like my hooker super comps arent very good.
Old Aug 3, 2005 | 02:45 PM
Well even if the gaskets are 50 bucks, its better than spending 15 for the first time, it leaks, and then you have to buy another one plus you have to go through the trouble of putting a new one on.
Old Aug 3, 2005 | 02:56 PM
Blu91Z28's Avatar
Engine: TPI 5.7 L
I like my Stage 8 locking header bolts! They're not cheap but I'm still using the header gaskets that came with my SLP headers, 2 years later!
Old Aug 3, 2005 | 04:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
he asked for the best, and imo, copper is the best.
Old Aug 3, 2005 | 04:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
any thing different for aluminum heads?
Old Aug 3, 2005 | 04:33 PM
phoenix305's Avatar
nope copper would probably be the best and those locking header bolts are awesome. they work so good.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
jharrison5
Aug 19, 2015 05:53 PM
dhonda200
Aug 11, 2015 11:50 PM
antares57
Aug 6, 2015 07:47 AM
