Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Will I see 14s?
Old Aug 11, 2005 | 09:37 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Will I see 14s?
Ok heres the full run down
1984 Camaro sport coupe with a 1980 350 LM1. Stock rated at 190 HP, 280 torque. Rebuilt 23k ago with stock replacement parts.
heres whats been done
AC delete
smog delete
edelbrock performer RPM intake
holley 600 cfm carb
vacuum advance curve kit
hedman full length headers (1 5/8th tubes, 3 inch collector)
th350
3.42s in back
Only accessory its running is the alternator. Not even power steering (for the time being)
Is it possible to see a very high 14 out of this setup?
Old Aug 12, 2005 | 04:48 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Maybe a14.99 if you're lucky...most likely low low 15's. You might bust a very high 14 if you have a stall convertor.
Old Aug 12, 2005 | 03:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
its all gonna come down to the launch. get it off the line as fast and hard as possible and i think maybe a high 14 is possible
Old Aug 12, 2005 | 03:54 PM
Engine: 355 TPI
I should have some decent 255s on back when I take it to the track. And i'll definitely be practicing my launch
Old Aug 13, 2005 | 04:45 PM
Engine: 355 TPI
alright well I'd also like to toss in the fact my car should be about 3500 lbs with driver
IROCThe5.7L
Aug 10, 2015 11:24 AM
1985bluecamaroz
Jul 1, 2004 10:34 PM
AllGoNoShow
Dec 19, 2003 03:05 PM
iroc_cragg
May 14, 2002 11:57 PM
Brian92RS
Mar 13, 2001 09:29 PM
