Will a 4thgen 8 point fit into a thirdgen?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
What's the difference between the cages if any? I'm looking at buying one from a 4thgenner and want to mamke sure it fits.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Debatable. Depends on the exact style of the roll bar/cage. Some of the interior may be different enough.
It doesn't really matter though. Since the rool bar/cage needs to be custom installed, the differences between a third gen and a fourth gen may not be enough to cause a problem.
The price of a kit isn't very much. The higher cost is in the installation. You can pick up a kit through Jegs or Summit for a couple of hundred bucks. Typical installation costs are $100-$150 per point.
It's called a cage if it includes a halo bar and a-piller bars. If it only has a main hoop and forward/rearward/tranny tunnel bars, it's only called a roll bar.
Engine: 355
Axle/Gears: 4.11
It's the Jeg's 8 point roll bar. Different p/n so maybe it won't work.
thirdgen = 550-940303k
4th = 550-944503k
Thanks.
4th = 550-944503k
Thanks.
3rdgenparts
Aug 5, 2015 11:57 PM
