will it see 10's????
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
with the addition of 3.73 gears will my combo(sig) see 10's in a 3100lb car? just curious, im still in the process of putting everything together and looking for a goal, any idea what itll run off spray? anyways any opions would be nice
Car: 91 z28
comp cams custom grind its .507/525 lift 280/284 duration its pretty lopy
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
with that small of lift , the duration must b advertized duration. i think thats kinda a small cam for the rest of your set up. but with a 200 shot
Car: 91 z28
its a grind for nitrous yeah but n/a it probably will hurt the motor the powerband starts at 3k and tops at 6500 its all race oriented
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I have to agree. With only .500" lift it must be a 230ish @ .050 cam which is very small for a 406 cubic inch motor with that intake and big converter. If that's the case, you'd be leaving a lot on the table.
Car: 1988 Iroc-Z
Change the cam and you can see mid 10's easy. Buddy of mine has a 406, 210 heads, hydraulic roller cam, vic jr intake and a 150 shot on a plate kit. His car is also full weight and runs consistent 10.5-10.6. He does consistent 11.6 on motor. Full interior, and street driven everywhere.
Car: 91 z28
well damn...lol any suggestions a what sized cam i should go with?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
cam specs in sig. VERY streetable and pump gas friendly....I have a vacuum canister and brakes are as good as a dialy driver.
You'll be 10's N/A on motor easily with the extra cubes and the bumpstick I had in my 388.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Car: 86' Z28
Engine: 355
I think your fine with what you got. That should follow the small cam, large head theory quite nicely. Plus you got a friggen 200 shot on top of that, launching off a transbrake. If that things hooks up, and DOESN'T run 10.9x or better, something is verry wrong. Especially in a 3100lb car.
Eric
Eric
Originally posted by 84firebird383
Whats the lobe separation on that cam?Also what distributor gear do you use with it?
I ordered the cam with the steel cam gear so I could use the standard iron distributor gear, I've seen too much damage casued by the bronze gears and wanted a motor that was low maintenance and street friendly, this cam ground by Bullet Camshafts was the ticket. Low lift did'nt tax my valve springs or other valvetrain components but gave great power along with excellent street manners and brakes, this car was very decieving to all that rode/drove it around town.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
It's a 106 LSA installed at 102.5*, recommended was 102, but 102.5 was as close as we could get it LOL!!
shoot me an email direct j.meighan@mchsi.com and we'll work out a price.
