Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
trans tunnel mods
Old Sep 29, 2005 | 09:43 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
trans tunnel mods
I have an 84, small block and a P/G. With the trans shield and convertor shield it get pretty tight and I have to lower the rear cross member to adjust the band. Has anyone modified the tunnel to make the install and maint any easier?
Old Sep 29, 2005 | 09:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I didn't have any problems with a PG with shield. I even have a flexplate shield. The PG is so small. Even when I had a TH400 with shield, I still had lots of room.
I now have problems but it isn't a tunnel problem. I had to lower my engine and tranny down for header clearance. I also moved the engine back about an inch. This cause problems trying to access the bellhousing bolts so I cut out the front part of the tunnel and fabricated a new one. It's all welded back in and sealed up. I might cut it out again to allow even more access.
fbirdroller
Sep 2, 2015 10:27 PM
Hello, Michael
Aug 20, 2015 03:19 PM
PestilenceIV
Aug 20, 2015 02:33 AM
matthew911
Aug 12, 2015 09:38 AM
mizz0313
Aug 12, 2015 06:45 AM
