What is considered a "fast" street car in the 1/8th?
Car: 85 Camaro Z28
Transmission: 700-R4
I went to the track last night, and saw all the street cars goin at it. A lot of fun, but LOTS of turbo mustangs that did not run consistant. Fastest was a 7.57, same guy ran a 8.22 the next run, and a 7.91 the next. He was in the street class, but was running ET Drags, and was a trailered ?
My whole idea of what is fast for a street car is based on 1/4 and not 1/8, so I was confused and couldn't figure out what was actually fast to me.
Saw a Monte Carlo S/S with a chip and exhaust pull consistant 11's in the 1/8 (why even try?)
No imports, but lots of 4th gens in the high 8's and mid 9's.
motorcycles were running low 7's for the most part...
Anyone explain to me what a 12 second 1/4 is in 1/8 mile time? geez
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1/8 mile time multiply by 1.56 gives a very close 1/4 mile time.
That 7.57 works out to an 11.8 and the 8.22 is only a 12.8. Both would be fast for a street car but I wouldn't consider it being a street car unless it could be daily driven on pump gas or driven across the country without the need for backup assistance.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
My opinion of an entry level fast car that could double as a daily driver would be somewhere in the 7s for the 1/8th and 11's in the 1/4.12 and 13 second daily drivers are still quick,but there are so many of them that I don't really consider it "fast" any more,just quick.Even 11's isnt that hard to do and still be daily drivable. It just costs a bit more.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah fast street car to me is one that touches 120+ in the 1/4mile. the 1/8 that would be high 80's and into the 90 mph range. thats a real fast street car. those are your bolt on pullied cobras, your cammed LS1's with full bolt ons and mild ls1's with spray, etc. a decently fast street car is 110-119mph to me.
et's dont realy matter to me as most street races are rolls and only mph applies. ET's are very impressive but your best et's are not gonna be in street trim. most guys run slicks or drag radials at the track and switch over to street tires on the street. a fast street car is one that can achieve those above times on street tires, street trim. granted drag radials are street tires and do somewhat alright on wear, but not the best in all conditions like handling and rain which a street car must deal with on occasion, in my book.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
now take my times to the Jersey area, Chi town, etc and it's a pooch...and you'd better be packin some low single digits if you think you've got a fast street car.
There will always be a debate about what a "true street car is" I say if it's DOT legal, licsenced, insured, pump gas operated going through the pipes...it's legal. DOT slicks are just a performance upgrade or different avenue IMO, no different than installing an MSD ignition. Both are race inspired but toally street legal-so where do you draw the line....it'll never happen so just have fun
Car: 89 Iroc-z
Transmission: TH400
fastest pump gas drags from Hot rod magazine... most cars in the mid 8's in teh 1/4 mile. and most no slower than high 9's
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Originally posted by Project
single digit "street" cars? What?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
check sig, no need for a trailer, and the closest track is 1.5 hours away from me. When I spray, it should go low 10's. But on spray, it's not a "street car".....
Car: 85 camaro
Engine: 605in bbc
Transmission: powerglide
Axle/Gears: 12bolt with 4.10's
low 6's or high 5's is fast to me...but i live on the ragged edge and run race fuel on the street..not legal but i can drive it on the street just cost alot.my 85 ran 5.70's at 125 and 8.90's at 154.
the trend i have seen is the more money you make and spend on your the less actual "streetlegal"means to you.alot depends on the crowd you run with also ..most of my friends cars run 5's and they still drive them on the street...but not everyday.
no matter what the cars run,it is all about the rush you get when mashing it to the floor..
Engine: 355
Axle/Gears: 4.11
race gas is for race cars. And slapping a license plate on a race car doesn't make it a "street" car. If they can't drive it to the track, race it and drive it home w/o changing anything but tire pressure, then it's not exactly a street car.
Pullin it off the trailer, making a 8 second blast and popping the chutte just to pull it back on the trailer, is a trailer queen.
Car: 85 camaro
Engine: 605in bbc
i have a racecar also..and it runs 7.90's at 3450lbs so suck on that.
Engine: 355
Axle/Gears: 4.11
I don't care what you have. A 25 mile cruise doesn't make it a street car either.
Drive thru please.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I agree with you completelty Freebird,but there are some very fast true street cars around.There is a Lightning pick up that runs at my local track that runs 9's and doubles as the guys work truck and is never trailord.There is also a very streetable 66 chevy 2 with a mild 496 that runs 11.0's on the motor and sprays into the 8s.There is even a 79 crazy insane transam that has run hi 7's on a 10" tire with a procharged 540 that is rumored to be quite streetable.I know I saw him drive it to the track at least once.
Car: 89 Iroc-z
Transmission: TH400
lingenfelter new C6 twin turbo put out 1080hp while spinning on the dyno....
that is VERY streetable. you can drive that all day to and fro whereever you want and should get somewhat decent mileage as long as u stay outta boost, yet has enough power to get 9's and probly 8's if set up right. trap speed is tremendous! well over 140's... thats really fast
the fastest street car that i know of today was Marco's Supra.. that made 1100rwhp on pump gas and over 1500 on race gas.
it ran 8.45 at 162 if i recall....in the 1/4mile of course at the 1100rwhp setting. crazy insane. full interior, etc.. a TRUE street car.
Car: 85 camaro
Engine: 605in bbc
Drive thru please.
Drive thru please.
Car: 1984 Z28
it ran 8.45 at 162 if i recall....in the 1/4mile of course at the 1100rwhp setting. crazy insane. full interior, etc.. a TRUE street car. [/B]
marco's supra has been very incredible to watch on the street getting down around chitown. definately a street car, yet he has more money tied into that car developing a system that works and stays in one piece than most of us has in our house.
Car: 89 Iroc-z
Transmission: TH400
yep, never said its gonna be cheap... to have a combo like that you need absolute best quality and strength. that means mucho dinero. someday i hope to dump a ton of cash into my ride to make it a true unique one of a kind monsterous street car
Engine: 355
Axle/Gears: 4.11
Originally posted by onefast85
your just another kid who can't see beyong what you own...someday you will mature.
I'm growing tired of your posts. Joined: Sep 2003
Car: 89 Iroc-z
Transmission: TH400
Good job on backing up your previous post w/ hard evidence of 8 second cars driving to the track and running on pump gas.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Car: 85 camaro
Engine: 605in bbc
I'm growing tired of your posts. Originally posted by Free Bird
if your car has brake lights, turn signal, headlights,and a muffler than u can drive your car on the street.There is no requirement on distance it could travel to be street legal.
yours comments on race gas, trailers,and chutes is just plain whinning to me.
Car: 1989 Trans Am GTA
Transmission: M28 T56
What about Sheps' 8 second talon?
http://www.dsmtimes.org/shepherd/8.55@176.9.mpg
http://vids.torquenstein.net/imv/ShepherdRacing.wmv
Its street legal, though I don't know if its much fun to drive on the street. And I don't think it gets good gas mileage.
again, check the hot rod pump gas drags.. dont need to back up with evidence as its out there... there are a lot of 8 second pump gas cars that can drive well on the street
The fact is that there is always going to be a gap between what fits assorted street car class rules at the track and what you’d actually have fun successfully driving around on the street.
There are some <11 second cars that are realistic for street use, but nowhere near the numbers that all the street car classes out there lead you to believe
Re: What is considered a "fast" street car in the 1/8th?
Car: 89 Iroc-z
Transmission: TH400
Wow oldy!
but now that its 13 years later, boy how times have changed
there are guys running 4’s in the 1/8 that are streetable and vast number in mid low 5’s just fine.
thats low 8’s to mid low 7’s 1/4 mile
efi and turbo tech makes it possible but even nitrous cars are doing it now
Car: '89 Firebird
Engine: 7.0L
