Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Any idea or guessing what this should run?
Old Oct 25, 2005 | 02:05 PM
demonband2000's Avatar
I have a 82 z/28 with the following
305 - runs and starts smooth, has a new cam that the previous owner put in but is a replacement stock cam
Edelbrock performer intake (no EGR)
Holley 750 vacuum, runs ok, carb might be to a bit to big- but thats all I had to put on it when I replaced distributer and CC carb
All computer stuff has been taken off, no AC, No CAT Converter, or stuff like that
Fresh tranny- built up- will catch rubber going into 2 and 3 gear
Fresh 3.73 Posi -
I know its not the fastes thing around, but if anyone has a guess I would be happy to hear it, it runs drives and starts good.
Old Oct 25, 2005 | 03:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you don't sit on the line spinning the tires, you'll probably run in the 15's.
Old Oct 25, 2005 | 03:25 PM
no problem with tire spin at all.
Any guesses- after a cam change (222 duration at 50)
Old Oct 25, 2005 | 06:08 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Sounds like a solid mid 15 second ride, low 15's if you can drive.
Old Oct 26, 2005 | 09:24 AM
five7kid's Avatar
Re: Any idea or guessing what this should run?
Sounds like a traction problem...
I didn't have traction problems when I went out for a time-only run on a regular race night and ran 14.4. A couple of weeks later, I went out on a "club" race night, spun so bad off the line I thought I had lunched the transmission, and ran a 15.5. That was with 2.93 gears and 245/50x16 GS-C tires.
Traction makes a huge difference.
Old Oct 26, 2005 | 07:54 PM
Nope, never had tractions problems, maybe if I had single track rear end it would. - But I agree that traction does make a big difference.
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
