What does every1 run in the 1/4 mile
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
what does every1 run in the 1/4 mile and what supporting mods u have. My 89 Ta ran a 16.03 @ 84mph with the mods in sig. My 02 Ws-6 M6 ran 13.32 at 107.7 with only a lid, K & N, and smooth bellows
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
www.preacherskid.jamaministry.com for specs on my combo that took me to 13.03@103mph.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
stock TPI/heads/cam
gutted airbox, headers and catback exhaust.
lots of suspension and street tires
2800stall
new 3.27 gears i went 13.98 at 100.9mph
old 2.77's i went 13.89 at 96.6mph
2800stall
Car: ws6
Engine: ls1
Transmission: m6
I ran 13.5 at 99 with the 3.42's,and 13.8 at 97 with the 2.77's.
Stock as a rock it ran 14.8@93
MODS
FlowMaster Cat-Back w/high flow cats from Cat-co, EdelBrock TES Headers, EdelBrock High Flow TPI Intake Manifold, EdelBrock High Flow Intake Runners, EdelBrock Air Foil In Throttle Body, Throttle Body Bypass, TPI Intake Manifold and Runners Ported by TPIS, TPI, Plenum Ported, TPIS Adjustable Fuel Pressure Regulator ,TPIS- ECM Reprogrammable Chip, Gutted Air Box, K&N High Flow Air Filter, ACSD 82-92 Camaro IROC TurboHood, HyperTech Chip Stage One ,HyperTech 160 Degree Thermostat, Re-mapped Injectors, MSN Ignition, Blaster Coil, Accel High Performance Rotor, Wires, Beefed up Alternator,Mass Air Flow Sensor [cut out fins] ,ARP Engine Fastener Kit, GM Crome Valve Covers, Synthetic Motor Oil ,3.42 Rear End ,245/50/16 Series Tires w/Iroc-Z Rims,Radials
MODS
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
10.69 @ 125.8 w/1.47 60ft
Buick V6, TH400, 12 Bolt, 3650lbs
http://www.cardomain.com/ride/411384
Steve
Steve
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Stock 15.1@ 90 with a 2.34 60' @ 2100 ft elevation
Now 14.49@95 with a 2.12 60' @ 2100 ft elevation
Basic bolt ons
SLP Runners
Catback Exhaust 2 3/4 W/Magnaflow muffler
AFPR
Shift Kit
3.27s
Ported Plenum/Runners
Gutted Air Boxes w/k&n's
Basic bolt ons
SLP Runners
AFPR
Shift Kit
3.27s
Car: ws6
Engine: ls1
Transmission: m6
Basic bolt ons
SLP Runners
AFPR
Shift Kit
3.27s
Basic bolt ons
SLP Runners
AFPR
Shift Kit
3.27s
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
305 ran 14.80's with just long tube headers, dual plane and 750cfm holley
355 12.74
388-in the sig
355 12.74
388-in the sig
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
In the video (see sig). My car has been down all year, but with the upgrades I've done, I hopefully should be able to shave off a tenth or two for next year.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
see sig, all motor runs. Now I think the block is cracked, still haven't had a chance to spray it.
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
Car: 1989 IROC-Z
15.2 @ 89 mph
k&n air filters, bottom of airbox cut out, exhaust dumps right after the cat, stock exhaust otherwise. stock suspension, 215/65/15 goodyear eagle gt-IIs. the engine and tranny are stock 65,000 mile components
Car: '82 Z28
Don't feel bad about the 18.2, I did a 22 @ 65 mph first time racing on sticky tires
I just about ended up in the back seat when the latch failed to lock on the driver seat
Tilted all the way back when I took off
Car: 91 z28
Last time out I ran a 14.2 @102.00 with a real nice 2.37 60ft. The 102 made me happy on stock heads and TPI. Since added stealthram and pro topline heads, but the nut behind the wheel still needs some work before it can drive a stick!
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
14.63 @ 95mph with a basically stock 350 from a '79 Z28, headers and exhaust, and a T5.
Should be quite a bit faster next season, as I'm replacing the heads, cam, intake, ignition, valvetrain, transmission and tires.
I'll be shooting for low 13s or high 12s next year.
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Dunno if you guys care buttttt.....
Bone stock 228k car with dry rotted/bald tires full weight
2.12 60ft
9.31@75MPH 1/8
3.73's/DR's/dumped exhaust
1.92 60ft
9.09@75.99MPH
Then modding time
Forged 306
STOCK E7's w/Trickflow spring upgrade kit
Lunati .500/.510 lift 218/226 duration
Cobra upper/lower
Holley 70mm TB
Aeromotive AFPR
Walbro 255LPH intank pump
stock 19# injectors w/stock Maf (still screened
Dual friction clutch
Hurst shifter
ProFab upper/lower control arms with Solid bushings
UNTUNED (literally
1.78 60ft (yanking the front drivers tire
8.66@79MPH
On my 5th pass, which yielded me a 1.75 60 ft and yanked the drivers side tire AGAIN, my motor blew half track. We figured with the 330ft and comparing my previous timeslips, it WOULD have run somewhere along the lines of a 8.3 or so pass (dropped FP to 37 PSI and BFG's down to 12 PSI, made it run MUCH better)
Now its down for the winter...coming back next year with more mods and 1/4 times....looking for high 11's/low 12's on the motor and low 11's/a high 10 on the 150 wet shot...we'll see
EDIT: BTW, this was on 15x7's all the way around, and only weight reduction we spare tire/jack removal (which was replaced by full Nitrous bottle) and fiberglass 3 inch cowl hood.
2.12 60ft
9.31@75MPH 1/8
1.92 60ft
9.09@75.99MPH
Then modding time
Forged 306
Cobra upper/lower
Holley 70mm TB
Aeromotive AFPR
)Dual friction clutch
Hurst shifter
UNTUNED (literally
)1.78 60ft (yanking the front drivers tire
)8.66@79MPH
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
with the original L69 305 i ran a best of 14.7@92 with only a gutted cat and hooker cat-back....
my setup now is in the sig...and i hope it will drop even more when i get some drag radials and a posi
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Here's my personal best so far
60' 1.680
1/4 11.827 @ 115.47
I know theres still some left in it i jsut have to find it somehow
60' 1.680
1/4 11.827 @ 115.47
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
