Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
95 Bird Head&Cam car 12.55at112
Old Nov 13, 2005 | 10:36 PM
m-greene's Avatar
Car: 1995 Firebird
Engine: LT1 350 LPE Heads compcam
Transmission: 6 speed
www.dnsphotography.com RT.531 60foot 1.93 12.55 at 112.03
still having traction problems on bfg street drags
thinking of bagging pass side coil ? i have BMR subframes
Bmr lower control arms and adj panhard bar
any ideals ?
Old Nov 13, 2005 | 10:58 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
dont bother bagging anything.
Just heat up those tires well and get your driving top notch. You should see a 12.1 with a good 60.
Old Nov 14, 2005 | 09:00 AM
crawlin 25th's Avatar
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
a torque arm helps alot .... hal's adjustable shocks work awesome as well... my buddy had a cam only lt1 camaro and goes 11.80s - 11.90s on motor with a 1.5 60 ft... he was using a 700r4 trans with 3800 stall and going off the foot brake....
Old Dec 2, 2005 | 04:49 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
u can probably do it
warm up the tires alil better dropp the pressure or if not on ure next set go to the mickey thompson drag radials ive had the bfg drags and the et streets and with the mickey drag radials i even hook more consistant i even pulled 1.7 60ft i went 12.2 at 111 there a better ride then the et streets and worked jsut as good or better on ure next tires go with the mt drag radials
Old Dec 2, 2005 | 09:00 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
LCA relocation brackets will help give you the axle-breaking traction your looking for.
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro71633
Sep 1, 2015 10:24 AM
drathaar907
Aug 10, 2015 07:44 AM
Fronzizzle
Aug 9, 2015 01:15 PM
