View Poll Results: What to do?
GET A CLUE! 2.3-2.4 60' sucks, PRACTICE your launch before you spend anymore money!
32.00%
Get slicks! You might as well you are only going to use them at the track anyway, and they hook best!
28.00%
Get drag radials, they will be more than adequate for your power level, they are cheaper, and they are less likely to cause stuff to break. Slicks are over kill in your situation!
40.00%
Voters: 25. You may not vote on this poll
What to do for traction?
Car: 1994 Jeep Wrangler
Ok, I know I just had a post up about this, but maybe I can get a larger volume of quick opinions with a poll. I am 99% sure I need to get some stickys in order to get the results I want in the 1/4 from my car. My current best times are in my sig. I figure with a good sub 2.0 second 60' I can get into the 13s as my car sits now. I have an extra pair of 16" Iroc wheels that the tires will be mounted to. (Don't say I should get 15s, I realize it would be more ideal, but that is not what I have) I WILL NOT drive these on the street or even to and from the track in order to preserve them as long as possible so that is not an issue.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
slicks. And practice. If you will always race w/ drag slicks, then always practice w/ them.
If you like to race DOT tire or drag radial classes, then practice w/ those.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Before you go any further you need a reality check.
how are drag radials not going to be any harder on parts and cause less breakage than slicks?? LOL The point of going to either option is to dead hook-which at your power level you will do. Dead hooking means just that-you WILL NOT SPIN A TIRE...so how does it matter if it's a radial design or bais ply design?? if sheeots gonna break it's gonna break-aint nothing you can do about it except be prepared because it will break at some point....your at a race track and that's what happens to cars at race tracks-they break!! not a matter of IF it's a matter of WHEN-go there enough and you'll see.
If your looking for the cheapest easiest solution-GET 15" rims and GET a set of USED bais ply slicks, dot cheater slicks-entire set-up might cost you $75 total and will last from what I gather with your intentions a long time!! You'll have better selection of tires avaible by using a 15" rim-why stuck on 16". I've got 5 sets of good slicks in my basement-each was new and I change them every month to stay competative-I promise somebody in your area is in my same boat and has tires to spare for cheap.
your not at a car show out there, nobody give a crap your back rims dont match-ALOT of cars run like that-it's a race track, not a car show. Your going in circles asking redundant questions and your going to get the same responses here as you did in the original thread you started.
NUTSHELL: at your power level either tire will work. FUTURE mods increasing engine output you will tax the tires if no suspension work is done. radials will not work on a bone stock car with alot of hp/tq under the hood. and when I mean work-I mean consistant 60's not varying more than .01 PER PASS ALL DAY. just cause you dont feel it spin dont mean it''s working
Car: '88 IROC-Z medium orange metallic
From 14.6's to 13's? Dont think so. Not with <97 mph. I cut consistent 1.83's on no-name street tires with all stock suspension on my LB9 TA. 3K stall and 3.42's. Learn to launch the car better. I'm not trying to be an *** but I think you're being too optimistic. You don't NEED slicks with the amount of power you're putting down.
BTW, I voted get some DR's. I think you have a clue or else you wouldn't be asking. Slicks are too much.
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
I like my BFG Dr's....I was dead hooking out of the hole, yanking my drivers wheel and only running 8.6's 1/8th's wqith 1.78-1.82 60's......If you get BFG's, you need to wear them down to near blad and then they'll hook liek a slick and still ridel iek a street tire
Originally posted by IHI
You're going in circles asking redundant questions and you're going to get the same responses here as you did in the original thread you started.
It does'nt annoy me persay, just an insult to those who have taken the time to help you out with their own experience and suggestions...at face value it's like smacking those who took the time intitally. The poll is fine, but same results-mixed opinons just as before.
Good luck with whatever you chose, either one will work great where your at now power wise, but slicks will last ALOT longer...so dont think about inital cost as much as long term since you'll easily go through 2 sets of radials to one set of slicks
my buddies have been there done that/
my buddies have been there done that/ Thread Starter
my buddies have been there done that/ About radials not lasting as long as slicks. How is that? Do you have to burn them up that much more to get them sticky?
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Numbah-1
Sep 12, 2015 08:57 PM
