what do you think ill run?? the common q
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
well current setup
1989 chevrolet camaro iroc-z 5.7 tpi l98 stock shortblock never touched.
t56 6 speed manual 94-97 gears, rebuild, centerforce dual friction clutch, spohn torque arm adjustable with cross member, slp steel billet 19lb lightweight flywheel.
trick flow specialties 23degree alumnium heads 195cc intake runners, 64cc chambers, 2.02in/1.6ex valves, 1.47" single springs
gm lt4 hot cam 218/228@.050" .525"/.525" 112LSA.
comp cams pro magnum steel rockers 1.6 full roller
summit true dual timing chain,
accel/lingenfelter super ram untouched runners and plenium
port matched edelbrock high flow tpi base
ford svo 24lb fuel injectors, adjustable fuel pressure regulator
edelbrock smog headers with open y pipe.
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
im planning on a similar setup for my and im thinking low 12's high 11's if u get good traction and a have a very good tune. and make sure u bang those gears quick to see high 11's
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if ur gonna see high 11's hahaha then i wonder what ill do? 10's? rofl
i say low 14's maybesomething closer like 14.2
Re: what do you think ill run?? the common q
Originally posted by porkyzilla
well current setup
well current setup
Engine: 5.7tpi 350,
your combo isnt gonna run im gonna be over at your house tearin down your new motor cause you threw another rod bishno i would be happy with a 12.8-12.7 at 109-110mph. with a 1.9 60ft, the best i could cut so far when motor was stock with my 6 speed was a 2.3 60ft, best run bone stock from the factory except the 6 speed swap was a
14.2 at 101mph with a 2.9 60ft
best with auto was 14.2 at 98mph with a 1.9 60ft
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I dont think you'll get anywhere near 11s. The hotcam just isn't tough enough. I'd expect upper 12s with traction. Which seems to be hard for you
What gears are you running?
Engine: 5.7tpi 350,
Car: '72 Chevy Nova
Transmission: TH350
Originally posted by brutalform
Found an old slip. 13.021@106.86 with a 1.682 60' on drag radials. BTW, my car was a stick back then too.
was that a hotcam?
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Originally posted by 1QWIKZ
What happened in the middle of the track? With that 60' and mph you should be in the mid 12 area...
I figure it was the crappy ASM prom that I wasted my money on. Also, I had some problems powershifting the Tremec TKO, I had at the time. No excuses though, I was still happy with it.
I figured it "might" have went 12.80s on a good day.
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Engine: 5.7tpi 350,
Originally posted by OUTATIME GTA
That's what I would expect too, but knowing Eric's car/performance so far, I say low 13's to start w/potential for better.
damnit
Car: 87 IROC-Z
Engine: 350ci
The Hot Cam isn't that bad really. Check out the MPH.
http://www.wku.edu/~nathan.plemons/htmls/corvette.html
Car: '72 Chevy Nova
Transmission: TH350
well that car also has 275ish cfm heads (from what I've seen regarding flowcharts on LE and CNC ported LT1s), 4.10s and a light chassis. Along with 1.7 RRs - porky is using 1.6s. Although I'm still a little surprised it went that high.
Car: 87 IROC-Z
Engine: 350ci
I do think his flow is around 270-ish. Not sure off the top of my head. Also, he wants 4.10's, he has 3.55's. Also, that time was with 1.6 rr.
Car: '88 IROC-Z medium orange metallic
12.50's at best if you can get it to hook, you can drive, and you put the right drivetrain combo together.
Car: 88 Camaro
Engine: 355
Yes, I know. I never got my old 355 in the 12s. I pulled, and sold the engine so I can start my new one, before it happened.
Well, my buddy had a slower '60 then you(1.8) and his mph was 105.xx and he went a 12.64....So, somewhere in the middle of the track your tune is not right..
j/k btw.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Fast355
Dec 2, 2016 06:33 PM
