Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Add to my suspension please.
Old Feb 28, 2006 | 12:01 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Ok,I have an 89 t/a ws6.I want this thing to hold corners like a racecar and would like to try some autocross events.I have a pro kit and Bilstein hd's,18" wheels,adjustable Spohn lca's,adjustable panhard.I am going to be picking up some Spohn sfc's to.When I do my 350 swap next winter I will be adding a tubular K member,and A arms. I know the subject has been beat to death but I would like more info on adding to the setup I already have.I live in the mountains and drive winding mountain roads everyday.
Old Feb 28, 2006 | 02:30 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
sounds like a really good setup and the only thing i would add to that would be polyurethane bushings on everything. it will make the car feel better than new.
Old Feb 28, 2006 | 05:58 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
you got it covered it seems...after all that stuff is on, a GOOD alignment is a must for optimum results.
Old Mar 2, 2006 | 12:53 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Sounds like you're off to a nice suspension start Steve.
Not sure about those wheels though.
I think auto-x's prefer lightweight smaller rims, not sure.
Pretty much have the same setup as me with diff. brands along with the WS6.
Definitely an alignment needed, and reloc. brackets to correct the geometry after lowering.
There are front end rebuild kits and the poly bushings as mentioned too.
Old Mar 2, 2006 | 09:31 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I am ordering my relocators when we get back from Florida and will have'em welded to the new rear.The rims will stay as I don't see them making that big of a difference for what I will use it for.I still need to ride in your car to see how the sfc's feel.
Old Mar 2, 2006 | 12:51 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Tires. tires. tires.....spend your money on the best tires you can afford. It looks as if you have a decent setup so far.
Old Mar 2, 2006 | 01:03 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I just bought all 4 Falken FK451's.Don't know how they are for autocross but I have had no traction problems with these tires at all,I have made some aggressive moves with them on this car and my old mustang.I just ordered my TDS wonder bar today.
Old Mar 2, 2006 | 07:39 PM
Car: '89 GTA
yeah, we'll go for a spin.
my ride is extremely stiff with the sum of all the parts, not just the SFC's, but the front end could use some nice replacement items to kill some more creaks.
i'll do the STB/Wonderbar/centerlink/idler arm rebuild stuff later.
i've never auto-x'd, but i would think she'd hold up well after the front end suspension is taken care of.
Old Mar 2, 2006 | 08:06 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
If i remember right 17s is one of the best sizes for road racing, and you also want lo profile tires so you dont have so much sidewall flex when you turn.
Old Mar 2, 2006 | 08:32 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I 255/35/18 fornt and 265/35 rear.I just bought my centerlink and idler arm too.
Old Mar 2, 2006 | 09:38 PM
Car: '89 GTA
damn dude, you don't mess around.
you've got more parts in the past 3 months than i get in a year!
Old Mar 2, 2006 | 09:50 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I want this thing ready for summer The centerlink is only 75 bucks for a Moog at Summit,the idler was 65 I believe.I want to hit up some of the road coarses that whats her name on the west coast boards runs.I also bought my es torque arm mount for 15 bucks.I have to go back on saturday so I'll buy my sway bar mounts too.
Old Mar 2, 2006 | 11:05 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
he's changing parts that i've already changed. I guess i have bad taste.
Old Mar 2, 2006 | 11:07 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
btw heres a pic of my original paint scheme on the car.
Old Mar 2, 2006 | 11:12 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Looks better blue.I am just upgrding the parts you already had.Just the shocks and struts right?
My wife is getting repainted for my birthday in may.That blue that was on the accord you sent me.Anymore old pics?
Old Mar 2, 2006 | 11:26 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
this is 3 weeks got it back from the paint shop. First time washing n waxing it. U could tell its old from my stock gta rims and the paint is shiny
Old Mar 2, 2006 | 11:27 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
Some old pics
Old Mar 2, 2006 | 11:28 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
another
Old Mar 10, 2006 | 05:11 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I auto cross mine. I haven't done as much stuff to the suspension as you have, but its solid. Its an 89 RS.
Front:
Stock brakes
32mm sway
sway brace (TDS equiv)
eurathane everything
IROC springs (cut)
Rear:
94 11.5" PBR
22mm sway
Boxed LCA
Boxed Panhard
Bilstein shocks
Wheels:
18x8, 245/40R18 Federals (240 tread wear)
Engine:
3.1 @.060 over (3.25L)
ported/polished/gasket matched
LS1 springs
.430" cam
8000rpm balance
MSD coil
Speed Density ECM
Custom EPROM
Random goodies (no AC, TB bypass, blah blah)
Tranny:
700R4 with shift kit
11x17 tranny cooler
Weight:
3100 total
1650 front
1450 rear
52/48% weight dist.
The car still understeers going HARD into a corner. Parts I have that are waiting to be put in:
4.11 gears
LSD
94 master cylinder
Wilwood prop valve
LCA relocators
Ed1LE
Sep 30, 2018 09:14 AM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
meeklay812
Oct 1, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
