Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
lt1 times?
Old 05-16-2006, 04:05 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
lt1 times?
ok a friend of mine has a lt1 swap with a 4l60e and 2500 stall. the rear has 3.73's in it. the motor is bascially stock but does have a comp cam in it specs are 220/230 .510/.510 114 seperation with 1.5 rockers. everything else is stock. the car weighs in at about 3500 (guessing). what do you think he will run in the quater and what kind of power do you think that this will make? stock wheels and tires no slicks or anything like that this is a street car, maybe some drag radials. thanks in advanced
forgot to mention that the motor is all stock but he does have full exhuast, pulleys, CIN, shift kit in trans, the car ran 13.5's to 13.6
Old 05-16-2006, 04:17 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well stock LT1 Camaros (93-97) ran low 14s in the quarter mile. Your friend should see similar times. Maybe high 13s with the cam and gears.
But there's only one way to know for sure.
Old 05-16-2006, 05:33 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Lt1 with a Cam, gears, stall and exhaust? If the tune and driving is good, I say mid to high 12's.
Old 05-16-2006, 06:08 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I'm confused, the motor is "stock" but it has a cam, pulleys, and exhaust.
Old 03-31-2013, 12:59 PM
I'llrocya's Avatar
Car: 1984 Camaro Z28 H.O.
Engine: 5.0. L69
Transmission: Automatic
Axle/Gears: 9 bolt disc 3.27 Posi
Re: lt1 times?
I ran my LT1 93 and 94 Camaro Z28's (both automatic 3.23 rear) with nothing done and did a 14.2. with Borla exhaust I did a 14.0. Also these cars had the Eagle GSC tires, some Z28's of the time came with smaller touring type tires and different gear ratio's that would have been slower, I'm sure.
Old 03-31-2013, 01:39 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: lt1 times?
Holy old thread Batman! Dennis, did your friend ever run the car?
Old 03-31-2013, 02:40 PM
DIGGLER's Avatar
Re: lt1 times?
lmao, this sucker is oooooooold
Old 03-31-2013, 02:46 PM
I'llrocya's Avatar
Engine: 5.0. L69
Re: lt1 times?
He's probably on his 3rd motor by now, ha.
midge54
12-27-2019 04:14 PM
midge54
01-29-2017 07:00 PM
TheExaminer
08-19-2015 10:07 PM
sreZ28
08-14-2015 07:48 PM
Thirim
08-09-2015 06:19 PM
Quick Reply: lt1 times?
