Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
my time, i need more power?
Old Jun 23, 2006 | 06:57 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
went to the track for the first time and put out some good time, maybe
car spec
stock carbed 350 with 882 head cheapo header and catback no cat 2"1/2
700r4 shift kit(manual) super servo/zpack stall 2200-2500 no lock up
4.11 posi
bf comp t/a 255/50/16
did five run one with my dad the other alone
1 with my dad 2 3 4 5
reaction .153 .389 .133 .294 .453
60' 2.034 1.999 2.050 2.001 1.944
1/8 9.461 9.320 9.278 9.277 9.267
1/4 14.914 14.656 14.621 14.626 14.602
mph 92.631 94.427 93.436 94.282 94.386
there was almost no spinning
race weight is about 3600lbs with me
I think its good but i want a second opinion
Seb
Old Jun 23, 2006 | 09:26 PM
Lash's Avatar
4.11's...too much gear?
Old Jun 23, 2006 | 10:32 PM
WickedTA's Avatar
Car: 85 TA
i would think that you should be getting a better time then that. My formula that i used to have was....
92 formula. 5.7l TPI
700R4
headmen headers, flowmaster exhaust. i managed a 13.99 out of it with stock gears which i believe were 3.23. i as well had a 1.98 60ft.
Old Jun 23, 2006 | 10:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your dad must be heavy. He's worth .3 ET. The car is consistent. Get those reaction times into the .0xx range all the time and you could win a few bracket races.
You need some better heads for more power. What rpm are you shifting at. What rpm are you crossing the finish line at?
Old Jun 24, 2006 | 09:11 AM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
shifting at about 5000-5500rpm and crossing the line at 5000rpm but i dont know my power band realy but i think I got power from 1500-4500rpm next time ill try shifting at 4500
yea my dad is heavy about 250lbs but he havent race a 1/4 since de 70's so i counld say no
Seb
Old Jun 25, 2006 | 08:23 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
If your only running it to 4500 then the 4.11's are a little much. Other than that not really that bad, depending on what you are calling "stock". Not too bad overall though. Have you done any tuning yet?
theshackle
Sep 17, 2020 08:26 AM
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
