Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
too hot?
Old Jul 28, 2006 | 11:29 AM
drag1LE's Avatar
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
too hot?
I really want to go to the track tonight to test out my new setup - 250 shot with my rebuilt T5. Haven't sprayed yet. No faith in the T5 lasting long, but what the heck?
However, forecast temps are mid 90's with heat index of 100 - 105.
Is this too hot? Would I just be wasting my time?
Any input is appreciated.
Old Jul 28, 2006 | 04:19 PM
brutalform's Avatar
Yea, forget about it. You definatley will not lay down a new best, and the track will be real greasy. Two weeks ago I went when it was 94*, and humid, my helmet was even soaked from sweating. Wait till a better day. Not real fun in the heat.
Old Jul 28, 2006 | 07:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's never "too" hot but days like that I want to go out in the first round. Sitting in a black car on the asphalt in a 2 layer fire suit is hard on the body. If you do decide to go, don't expect any personnel best runs.
When I used to run my daily driver truck on days like that, as soon as I crossed the finish line, the AC was turned on and I cruised back to the pits in comfort.
Old Jul 31, 2006 | 08:35 AM
drag1LE's Avatar
Engine: 6.0L
Well, I decided to go. . .sheesh. 1/8 mile track - Eddyville Raceway, Eddyville, IA
95 degrees at the beginning, 91 by the time the track closed. You're right on the money - track was greasy as sin. I usually 60' @ 1.5X, but couldn't get better that a 1.77, and that was only twice. As the night went on, my 60's started going 1.8X.
So I only shot 150 (figured 250 would've been a waste because of track conditions) with my progressive controller set up for 0% initial and 100% @ 7 sec.
Here's the (best) results:
60': 1.82
330': 4.95
660' (1/8): 7.43 @98
ET wise, that's only a tenth better than my best on motor (7.55). Speed wise it's 8 mph better. So, I'm losing all my ET from the lousy 60.
I figure 98 in the 1/8 ought to be good for at least 7.1X.
Old Aug 1, 2006 | 11:39 AM
drag1LE's Avatar
Engine: 6.0L
. . .and I'm being told to remove the front sway bar to help with weight transfer.
Opinions?
Old Aug 1, 2006 | 12:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
definately remove it.
Old Aug 1, 2006 | 01:27 PM
drag1LE's Avatar
Engine: 6.0L
Hey thanks, I appreciate the help. I think I'll remove it.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
