Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
sidestep the clutch
Old Sep 28, 2006 | 07:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
sidestep the clutch
What does this mean anyway?
Old Sep 28, 2006 | 08:01 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Also known as a powershift, or speedshifting- NOT advised with a T5!
It means to never lift the throttle between shifts with a manual!
Old Sep 28, 2006 | 08:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
ah, thank you. My T10 doesn't seem to mind it on the 1-2, but 2-3 i've managed to slam it back into 1st once, so i'm a little cautious about doing it now.
in your sig you listed all the things you own with an engine in it... including your weed eater? mmmkay... what, your blender didn't make it on there?
Old Sep 28, 2006 | 08:17 PM
Car: 3
Engine: inboard
Only listed the fossil fueled devices. I need to update that list though!
Old Sep 30, 2006 | 12:38 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
It means to keep your foot on the gas AND let the clutch pedal slip off of your foot rather than using your leg in a controlled release of the pedal.
Fast, but I don't recommend it....
Old Sep 30, 2006 | 01:09 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
keep the right foot to the floor, step the clutch down to the floor, move the shifter and side step your foot to the left to let the clutch "pop" back up on its own.
Old Sep 30, 2006 | 04:41 AM
Sonix's Avatar
Car: 1982 Trans-Am
ah, ok, that makes sense. I think pulling my foot back is quick enough for me..
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
