Raced my car this weekend
Car: 87 iroc
Engine: mild 350
Transmission: 350 turbo
I ran my car at st thomas dragway, ran a 11.47 at 117 mph with a 1.56 60 ft. 350 .060, mild comp camshaft, 441 smog heads, 4000 stall 3.73 gear 3100lbs with me in it!! this is to all those ppl that look down on smog heads, they seem to work awesome on my motor!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Smog heads are only considered smog heads when using flat top pistons which produces low compression ratios because of the 76cc combustion chambers. Large open chambers unshroud the valves and help the engine breath better. Bump up the compression with some dome pistons and you make more HP.
With some 2.02/1.60 valves and just some basic port work, any "smogger" head will perform well.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have to be honest and say that at the BEST I would imagine those heads to perform one second ET slower than what you posted. I'm really shocked that a cam that small, a performer intake, and the rest of your combo netter you a 11.47 at 117mph. That is faster than every post i've seen with a vortec headed combo at the track, by .4 and 4mph. The vortecs should blow those heads out of the water for low-mid lift flow. IF those times are real I just have to say congrats.
Car: 87 IROC L98
Power to weight puts it in the 385 - 405 hp to the wheels. Still a little high with such a small cam.
Those cam specs don't make any specs. Got a cam part number? It's sounds like it's a Stock Eliminator camshaft grind. Low lift and tons of duration. Engine probably doesn't idle below 2000. The 4000 stall conveter is probably good for that cam but should have more gearing.
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Car: 87 IROC L98
Thanks.
That's still an extreme camshaft. Comp Cams doesn't even list one with that much duration and such low lift. That's where all the power is coming from.
Car: 1984 Z28
224 @ 0.050 is a big duration? Also I don't see how old nascar slicks would hook well enough to run that 60'
Car: 87 IROC L98
With only .436" lift, yes. The lift should be somewhere in the mid to high .4xx range with that much duration and 300 advertised for such a small lift cam is huge.
Cascar not Nascar. Cascar slicks are a hard rubber, tiny tire. I've known a few people who have used them. You can pick up used ones pretty cheap but they're not a drag slick.
Car: 87 iroc
Engine: mild 350
yeah my signature is old, i run et drags 26 x 10 @ 14 lbs, and your right that camshaft doesnt exist. its a custom grind! i think it does have an extreme energy exhaust lobe. its a fast one i know that. sorry again my sig is old its got 498 lift intake 480 exh, dur is around 278 int. sorry if i mislead i just havent been on this site in a long time so i havent updated it! its a performer rpm intake 750 dp, flat top pistons dual valve relief just a coated speed pro, block zero decked approx 9:1 , stock rods arp bolts, stock crank, block 0.060 over, one 441 head one 126 head(same heads, flow 245 at .500) 3 angle, roller rockers, no exh, about 12 " worth of collectors. I was plannin on the car running 80's-90's but it went 11.47. I was shocked!!! I also reweighed the car today it was 3050lbs me in it and half a tank of fuel. i shudda updated my signature before i posted that,lol, if u wanna see a vid clip of it go on myspace www.myspace.com/stevefoster1985, then click on videos, u have to have a myspace account to watch it tho. sorry about the confusion!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was going to post a great big BS flag. That was a significantly more tame combo than I have, and I'd bet I have a hard time going low 13's.
278* intake advertised duration?
How'd you get the car so light?
Still, I think you've done damn well, I only hope I can go 11.5!
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
