Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
estimated e/t
Old Nov 13, 2006 | 07:05 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
estimated e/t
i recently had a 355 2 bolt 882 heads 440/440 lift cam holley street dominator and 650 carb with stock 700r4 trans and it ran 14.14. the motor spun a couple bearings. anyways i baught a bigger cam for it 488/510 lift with 240/244 duration got new pistons wich will put the compression ratio to about 10:3.1 same intake and carb might get new heads but with the same heads and with a turbo 400 shift kit and 3500 stall what do you think it will run. thanks
Old Nov 13, 2006 | 10:09 PM
Car: 1987 iroc z
will it atleast break 13's
Old Nov 13, 2006 | 11:12 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
oh god...I would hope so at least.
Old Nov 13, 2006 | 11:44 PM
Car: 1987 iroc z
what would be a good guess on what it would run
Old Nov 14, 2006 | 01:03 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
13.7 ditch those heads for ANYTHING and go faster.
vortecs, L98s, 113 casting vette heads, whatever
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
ws6transam
Jan 31, 2001 07:18 AM
