Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Will this setup get me into the 10s?
Old Mar 9, 2007 | 12:13 AM
tap2k's Avatar
I am currently building this car and I am wondering if you all think it will go in the 10s when its done. Here is my setup: 87 Camaro 350 4-bolt block border .030 over, forged Scat crank and rods, JP pistons, 10.3:1 cr, Comp cam (284 int 305 exh duration, .507 int .525 exh lift), Performer RPM heads, victor jr intake, 750 CFM holley 4150, 150 HP nos shot, moser 12-bolt, 4.11 gears, TCI TH400, 3800 rpm stall. Spohn torque arm, QA1 shocks, lakewod control arms, 28x12.5 rear slick. Car will weigh in around 3200 lbs with me in it. Any thought on how it will do on the track?
Old Mar 9, 2007 | 07:05 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
mid to high elevens on the nitrous. High 12's on the motor
Old Mar 9, 2007 | 11:55 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
11s on spray
Old Mar 9, 2007 | 05:11 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Need a bigger shot of spray to put that into the 10's.
Old Mar 9, 2007 | 05:31 PM
tap2k's Avatar
How much bigger? I know the motor will take a much bigger shot but im worried about the transmission holding together. I am thinking it might be lighter then I originally thought. I am switching to manual steering and ditching the ac and smog pump. Plus the interior is gone, just gonna be a roll bar and a racing seat.
Old Mar 9, 2007 | 06:10 PM
DIGGLER's Avatar
i think i could run well into the 10's with that and a 150 shot..... maybe low 10's.
Old Mar 10, 2007 | 08:57 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Old Mar 10, 2007 | 09:13 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I think its extremely doable. If you haven't bought the cam yet BUY THE NEXT SIZE SMALLER! that cam is huge for your motor. Go with the NX274 which is 230/244 @ 050. My 10:1 350 with untouched Vortec heads and the Nitrous HP 274 went 12.60's on motor and on a 150 shot I never managed to get a clean pass because the car wouldn't hook but it went 11.62 @ 117mph with a 2.0 60ft... If I could have repeated the 1.5x 60ft's I've done in the past I'm sure that would have been a very low 11 second pass.
So think of this... if my car with worse heads, restrictive single 3" exhaust, non-hooking stock suspension, few hundred lbs heavier, and absolutely no tuning whatsoever trapped 117mph there is no reason you shouldn't be able to do, atleast, a little better and crack off a 10.90 at worse.
Old Mar 10, 2007 | 10:49 AM
DIGGLER's Avatar
yup. my stock LT1 with a cam runs low 11's on motor.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
