TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,148 Times in 749 Posts
I have both TQ arm mounts from moser one (on my car) is the cast one and the one on the shelf is the welded steel unit that came with my housing and axle package. Dont remember when I got mine, Im thinking around 93ish??
Quote:
you are about the only other person i've found that has seen one of the welded ones. lol Originally Posted by TTOP350
I have both TQ arm mounts from moser one (on my car) is the cast one and the one on the shelf is the welded steel unit that came with my housing and axle package. Dont remember when I got mine, Im thinking around 93ish?? is the cast one much lighter?
TTOP350
close
- Join DateOct 2001
- LocationIl
I honestly don't know! I can weigh the welded one fairly easy..Originally Posted by DIGGLER
you are about the only other person i've found that has seen one of the welded ones. lol is the cast one much lighter?
five7kid
close
Quote:
How many hard launches with sticky tires have you made?Originally Posted by DAVECS1
Spohn now offers a Solid rod end just for this and that is what I am using. It has no side to side play. Had to be convinced a little to go intot he Torque arm bracket. I have put about 6000 good hard miles on everything with no issued to report so far. I'm assuming you replaced the QP spherical rod ends with solids, correct?
My Trak Pak TA didn't have sphericals. But, since the TA mount bracket couldn't squeeze down on the upper link like it does on the bottom link, the bottom link, which is the adjustment link, took all the side-to-side load the QP spherical rod ends allowed. 16th hard launch, the TA adjustment link snapped, putting the pinion skyward (lots of carnage). If I could come up with a way to keep the QP mount from swinging side-to-side, I'd put the Trak Pak back in (using a non-adjustable Jegster right now, and I'm not all that impressed with it).
No the newer Spohn TAs come with big solid ends on them. In essence the TA is solid and has no flex. Originally Posted by five7kid
How many hard launches with sticky tires have you made?I'm assuming you replaced the QP spherical rod ends with solids, correct?
I looked all this over quite a bit as I am kind of a suspension nut. I am using the stock replacement TA as it does not have the changing instant center like the aftermarkets do. I just made a bracket on my cross member to take the TA load off the trans.
Have not had the car on the 1320 but I run Nitto 555R 305/40/18 and I have put some MT drag radials on it. I have not had any issue. Also I screwed up on day and pulled my car onto a soft beach. I got luck and was able to launch my car out of that back on to the pavement. I was lucky not to loose an axle.
The car will see the strip at some point, but I am really not concerned, I feel I have put it through the ringer already and it is holding up.
What are you guys doing for the vent?
i run a rubber hose to the middle of the back bumper so that if it does puke anything it won't get on my slicks
