Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Can I got mid 11's??
Old Apr 9, 2007 | 07:08 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I want to know what you think my combo is capable of. When it was a street car d/d with edelbrock tbi headers and a 2 1/4in y-pipe with single 2 1/2 inch exhaust, all stock suspention with bfg drag radials and a stock 750 double pumper it went 12.7 at 107mph with a 1.7 60foot. wow thats alot of sevens lol. anyways, now it is completly gutted, dash and all, custom wireing with everything on switches, lakewood drag struts with moroso trick springs, and no sway bar, and worn out v-6 rear springs, battery in truck, open hedman long tubes, 750 double pumper with proform main body, tremec tko-600 and the same 3.73 posi rear it had be4. Oh yea its a 355, 9.6 compression, vortec heads with the guides milled and better springs,xe274 cam, performer rpm intake and full msd. thanks
Old Apr 9, 2007 | 07:27 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
Re: Can I got mid 11's??
thats the olny differences?, so you changed the headers, did a lil weigth reduction, and new carb, the trans will most likely slow you down in the 1/4 mile unless you can drive like a bat out of hell, if you had an automatic before youll prolly pull the same short times with the tko, and the headers and carb didnt add that much power, ithink youd be lucky to get low 12's
Old Apr 9, 2007 | 07:32 PM
Car: 89 Formula
Engine: Carbed 5.7
it was a t-5 before, never an automatic, you dont think going from a 2 1/4 single exhaust to open long tubes and full drag suspention and probably 300 pounds of weight gone will help? Everywhere I look 107mph seems to be around a 12.4 so I thought my exhaust was holding me back or somting... any idea?
Old Apr 9, 2007 | 08:32 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
then id say low 12's, high 11's if yourt lucky
Old Apr 19, 2007 | 08:51 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Hey
Got a 383 Fastburn
Same tranny as you
Moser 9" Rear 389 gears
Coil Overs and Spohn Suspension
Can get in more detail if interested
Running low 12's aiming for 11's to
Best time is a 12.12 with bad tune on drag radials ( not slicks )
Old Apr 19, 2007 | 01:11 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Sounds like your combo was REALLY kicking *** before, that exhaust was definetly holding you back. I think you'll do LOW 12s, high 11's. 7 tenths is a big stretch but with 300 pounds out of the car, a new suspension setup, and better flowing exhaust I could see you cutting that off. If you get some tuned length collectors in your long tubes you should probably be able to knock off another 10th or 2.
Old Apr 19, 2007 | 08:18 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
get it on slicks, and get that 60ft as far down as you can.. then maybe you'll go high 11's, more likely a low 12 though.. i doubt you have enough motor for mid 11's..
cowansauto
Apr 3, 2025 12:51 PM
PestilenceIV
Sep 11, 2016 12:53 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
