Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Almost done, what will i run question
Old Apr 14, 2007 | 01:38 PM
nightkid1357's Avatar
Car: 1986 berlinetta
Axle/Gears: 10 bolt with 3.73s
Iv posted my build in the engine board before, and asked what I would run, but I think this is the better place to do it.
I have an 86 berlinetta that came with a 305 and now I'm putting a 350 in it.
Comp cams xe262 cam
edelbrock performer intake
ported heads cut for 1.9x intake valves
650cfm holley DP, mech. choke and secondaries
Those are the things that I have done, or already have. Exhaust is pretty much stock with a dynomax 2.5 inch catback. What could I run with this combo?
Sometime after the engine is broken in, and I can build up some more money, I plan on getting hooker 2055s, to a 3 inch catback, with a high flow cat.
I'm going to get a posi unit for sure, and gears if i can figure out what I need.
What times can I expect after those mods?
Old Apr 14, 2007 | 03:04 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Re: Almost done, what will i run question
What tires, tranny, converter, gears, race weight etc?
Old Apr 14, 2007 | 03:12 PM
tires-stock width street tires, but they are brand new
tranny-700-r4, shifts pretty strong, but will be getting a shift kit too
converter-stock
gears-2.73s, stock
race weight- no idea, but it has electic fan, NO computer stuff or polution control/air stuff. engine bay had a ton of stuff removed that it didnt need.
Old Apr 14, 2007 | 05:37 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Maybe mid to high 14s if you can get a decent 60' and into the 15s if you don't. I would think a VS carb would be better suited to your combo.
Old Apr 14, 2007 | 06:51 PM
Is that with the exhaust and posi? or an as is estimate?
I got carb for $150 from some ebay company, its rebuilt and everything and it looks good.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
