Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What should I run?
Old May 14, 2007 | 07:51 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
What should I run?
1984 Trans Am
355- worked heads, 1.6 roller rockers, Edelbrock Torquer manifold, Holly 600, Hedman shorties, small cam forgot the specs, lift is around 420, accel hei super coil, cap and rotor, 300+ wires, 5-speed, posi 3.73's, no a/c...
Also Im looking into some new aluminum heads, wich ones would give me some good torque numbers.. Im looking for a real flat curve.. Thanks
Old May 15, 2007 | 07:10 PM
Re: What should I run?
Anyone??
Old May 15, 2007 | 07:19 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
carb is too small, intake is wrong, rest looks alright, but the cam is small side as well
what is the casting number on the heads? If I had to guess it would be 13s-14s
Old May 15, 2007 | 07:25 PM
I wanna get a Z-cam, 491/497 and 236*/244* and change the carb but Im used to FI and not too hot on carbs.. im thinkin a 750 but would that be too much?
Old May 15, 2007 | 07:27 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
cam and carb should be alright, there both on the small side, but you can take that torker intake and throw it in the garbage. If I had to guess, I'd say 14.2-14.8's depending on how good you can lanch, and how good you can shift. Good luck, and have fun!!
Old May 15, 2007 | 07:32 PM
any advice on the intake then??
Old May 15, 2007 | 07:40 PM
xpndbl3's Avatar
Car: 1984 Z28
ditch it and get a performer RPM air-gap, along with a 650/750 holley double pumper. Along with whatever heads you have and a cam matched to it and it'll run a lot quicker.
Old May 15, 2007 | 08:08 PM
Thinkin this carb HLY-0-3310S, a Weiand Stealth Intake.. not too sure on the cam tho.. would that Z-cam be a good idea?
Old May 15, 2007 | 09:25 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
not any experiance with that cam, but the other guy is right, get a performer rpm airgap.
Old May 15, 2007 | 10:41 PM
xpndbl3's Avatar
Car: 1984 Z28
no the 3310 is a vacuum secondary carb and is not performance orientated, save that carb for a tow vehicle or motor home. You want a 4150 double pumper and the performer RPM air-gap intake. I like the comp XE lineup and lunati voodoo lineup, but it depends on your heads which you can't seem to answer that question either.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
