Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What do you guy's think?
Old Jul 21, 2007 | 03:19 AM
camaronut79's Avatar
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
of my car that is I just got her done
83z
8pt cage
subframe connectors
gutted
stock 10bolt 3.42 gears tires are 26/10.5/15's
10 gallon fuel cell
holley black pump -8 line from cell to regulator then -6 to carb
motor
11:1 388
ported dart iron eagles 230cc intake runners 64cc combustion 2.08in 1.60exh
I ported them, and flowed them myself I have flow # if you want.
port and gasket matched vic jr intake
crane solid tappet lift .518in .536exh .244in .256exh dur @.050 106lsa
1.6 full roller rockers
holley 850dp
accell super coil
accell dizzy
msd 6al box
hooker super comps
true duel 3" exhaust
th-350 trans
3500 stall
B&M shiftkit
B&M adjustable modulator
Heres a few video's
burnout
http://video.google.com/videoplay?do...21509430310109
idle
http://video.google.com/videoplay?do...84084058243153
launch
http://video.google.com/videoplay?do...61859363189884
just the usual questions what do you guy's think it will run? how much power am I looking at? any one here running a similar setup???
Old Jul 21, 2007 | 01:01 PM
DIGGLER's Avatar
Re: What do you guy's think?
dang that cam doesnt sound nearly as aggressive as i thought it would with the duration it has....
just guessing, i would say the car should be good for low 11s. but, thats just a wild guess. just gotta see how it runs at the track.
Old Jul 21, 2007 | 01:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
reminds me of how my car used to look back in the day, it was 7 shades of black with faded clearcoat rolling on those rims. heh. I'd say it needs more stall and gear, but other than that it sounds good. Right now it'd be somewhere in the 11s once completely set up. Those are really big heads to not spin that motor up higher out of the hole.
Old Jul 21, 2007 | 01:27 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
no vids at work, but sounds like a stout combo. Just wondering, do you have some pics or a link to an album?, specifically any pics of the fuel cell, just wondering how you have it mounted. Anyway good luck, take it to the track and let us know what she runs!
Old Jul 21, 2007 | 02:12 PM
Car: 1983 z28
Transmission: th350
i'll get some pics for you today
yeah I wanted more stall but I have been trying to save up for a better rearend moser 12 bolt maybe
Last edited by camaronut79; Jul 21, 2007 at 02:14 PM. Reason: Automerged Doublepost
Old Jul 21, 2007 | 04:33 PM
xpndbl3's Avatar
Car: 1984 Z28
definitely should get shots of everything on the car and make a cardomain site with all them.
Old Jul 21, 2007 | 05:54 PM
Car: 1983 z28
Transmission: th350
heres some links first one's are pics of the car 2nd one's are pics of the motor and heads
http://rides.webshots.com/album/559946537lHRqBM
http://rides.webshots.com/album/559744529NVqKiq
Old Jul 21, 2007 | 07:25 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
that launch look like a low 15 car and as someone already said that cam dont sound that big but prove me wrong now
Old Jul 21, 2007 | 07:45 PM
Car: 1983 z28
Transmission: th350
well with the 1.6 ration rockers I have that would make lift .552in .571exh does it not the car is still untuned I checked the timing after those vids and it was at 26* total 4* initial it's also running a good bit rich. in the vid of the launch all I did was spin and I didn't even load the converter up.
Old Jul 21, 2007 | 08:09 PM
intex1982's Avatar
load it and put some tires that dont spin there video it again and post and i mean prove me wrong with time slips
p.s. that rubber fuel line won't ever make it through tech
Old Jul 21, 2007 | 08:37 PM
Car: 1983 z28
Transmission: th350
the line from the regulator to the carb?
Old Jul 21, 2007 | 09:55 PM
intex1982's Avatar
total u cant have more than a foot of rubber feul line and it looks like u have more than that.
Old Jul 21, 2007 | 10:01 PM
Car: 1983 z28
Transmission: th350
even on a street car??? didn't factory carb car have more than a foot?
Old Jul 21, 2007 | 10:12 PM
intex1982's Avatar
yea nhra rules i had to fix mine. but ur car should be good for 11 easy once u get it tune rgt. that a great cumbo tho i think right now ur run on maybe 60% of what power that motor has
Old Jul 21, 2007 | 10:13 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
even on a street car. you need to have some kind of NHRA approved line in the car, wether it's a braded steel, an aluminum hardline (which i see you have alot of, very good making the fuel system happen on a budget ), or the new twist lock line. it's the blue rubber line that's a better compound and will withstand higher line pressures and more types of fluids.
one thing though, you will have to build some kind of firewall to seal the hatch from the rest of the car since you have the fuel cell going inside the car. not necessarily the way i'd have done it, i'd like to see you run a regular tank, maybe one with a sump.
tune the car, add more gear and a real tire and run it at the track. something just didn't sound right in your burnout video. the motor was REALLY ******* down. i think that those cylinder heads should make far more power than the motor sounds like it's making.
Old Jul 21, 2007 | 10:43 PM
Car: 1983 z28
Transmission: th350
i'll get the fuel system done up right. those video's I never got above 3200 rpm and the timing being as out of wack as is was was messin with it to. ill make some more video tomarrow. what did'nt sound right to you could it be the carb??? anyways as far as the firewall its surrounded by metal on all sides and there is a lid attached to the body on the top that seals that little compartment could I just put sheet metal on that?
Old Jul 21, 2007 | 10:55 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
looks pretty good....should be suprised to see 11's on the time slip
Old Jul 22, 2007 | 12:24 AM
JesasaurusRex's Avatar
f*g
honestly it sounds like you have WAY too much valve lash...or maybe ur fans hitting something and causing that weird tick...did you move a decimal over one spot by accident or somethin when settin the lash?
Somebody already commented on the fuel cell thing, that'll never pass. Yes the 12" of rubber hose thing is true...you're a big boy
Last edited by JesasaurusRex; Jul 22, 2007 at 12:29 AM. Reason: Automerged Doublepost
Old Jul 22, 2007 | 12:30 AM
i just listened again...maybe i'm just hearing things
Old Jul 22, 2007 | 12:31 AM
Car: 1983 z28
Transmission: th350
Old Jul 22, 2007 | 12:32 AM
Originally Posted by camaronut79
i was hearing something that didn't sound like valve lash the first time around...didn't the 2nd...i drink too much
Old Jul 22, 2007 | 12:36 AM
Car: 1983 z28
Transmission: th350
my rockers are very noisy they were like that when I had a hyd cam cam was lashed to .026 per the cam card. SO WHAT IF IM BIG!!!!! LOL
Old Jul 22, 2007 | 01:34 AM
Car: 91 z28
guys, the fuel cell is closed off in the hatch area with the factory piece. Theres a guy on here with a teal camaro ( camaro 10.99 or something like that is his name) that has the same thing and its just fine.
Old Jul 22, 2007 | 06:58 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
When you buy the new rear make sure it at least has a 4.10 and if its only running on motor I would use a 4.30 gear. What are the flow # on heads did you do a before and after flow test? I think it will run 11.5 with a gear swap.
Old Jul 22, 2007 | 08:12 AM
Car: 1983 z28
Transmission: th350
Before:exhaust Before: intake
.100- 46cfm .100- 64cfm
.200- 95cfm .200- 132cfm
.300- 135cfm .300- 185cfm
.400- 159cfm .400- 227cfm
.500- 168cfm .500- 243cfm
After:exhaust After: intake
.100- 50cfm .100- 69cfm
.200- 102cfm .200- 133cfm
.300- 145cfm .300- 195cfm
.400- 177cfm .400- 247cfm
.500- 192cfm .500- 280cfm
Old Jul 22, 2007 | 08:52 AM
Car: 91 z28
pretty good flow #'s my AFR comp 210cc's + a little extra hand porting, flow 318/236 @.600 28" water...tony mamo is a god.
Old Jul 22, 2007 | 09:07 AM
Car: 1983 z28
Transmission: th350
yeah I didn't go to .600 wish I would have now I know it would have been very close if not at your numbers at .600, all my stuff was at 28" as well
Old Jul 22, 2007 | 09:14 AM
Car: 91 z28
yeah probably would have been close, but dont forget i'm working with 20cc's less! Im assuming you're a machinest by trade?
Old Jul 22, 2007 | 09:39 AM
Car: 1983 z28
Transmission: th350
yeah I know AFR can make a bad *** set of heads. I can run most if not all machine tools, but getting a job as one is hard.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
