Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
traction
Old Aug 3, 2007 | 10:10 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
traction
i just have a simple question whenever i go out on the street and spin the tires they both spin but whenever i go to the track and try and do a burnout only one wheel spins. i jacked up the car and rotated the back wheels and they both rotate the same way so i know i dont have an open diff. so what is the problem can limited slip diff's were out and is there anything i can do. thanks
Old Aug 4, 2007 | 12:26 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Re: traction
yes, posi's will wear out. The friction discs/clutches wear out just like they do in transmissions. Never checked into a rebuilt kit for them, but the parts are out there to get it rebuilt....no a big deal actually, just takes a little free time and brake clean to get all the old sludge out of it and install new discs.
Old Aug 4, 2007 | 12:42 AM
JesasaurusRex's Avatar
Re: traction
i gottta 3.73 mini spool rear for sale
Old Aug 4, 2007 | 01:07 AM
Car: 1987 iroc z
Re: traction
i was thinking since i can spin both tires on the road. should i just skip the water box at the race track and try to do the burnout. im building up a 9" for it and dont really want to wast any money on the 10 bolt you think if i put new diff fluid in it that it would help out. thanks
Old Aug 4, 2007 | 03:08 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: traction
hmm if you cant do a burnout in the waterbox, you'll probably have a harder time without the water. The street is pretty slick compared to the burnout box at a track
Old Aug 5, 2007 | 02:23 PM
83 Crossfire TA's Avatar
Re: traction
If you're building a 9" I don't know why you're worried about it, but trying some gear lube without any friction modifier will cause the clutches to grab harder.
FWIW, none of the 3rd gen posi's are rebuildable besides the cone posi in the BW 9 bolt.
Old Aug 5, 2007 | 05:54 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Re: traction
Try these guys here. They have been building High performance rearends long before moser or currie. They built my 12 bolt over 15 years ago and its still kickin ****. They sell everything you need to rebuild a rear end.
http://www.tomsdifferentials.com/
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
