Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Every time I relocate battery to trunk, starting power sux!
Old Aug 25, 2007 | 12:00 PM
87_TA's Avatar
I have relocated several batteries to trunks, everytime I loose significant starting power, Just did the 94's last night - went from awesome cranking to
struggling! Anything I am doing wrong of not doing? Have a good chassis ground at rear of car, have an engine to body ground. I know that increasing length of battery wire will do that, but seems lots of people do it without any trouble.. Only think I can think is reduce the length of power wire, I can maybe get 3 feet off of it..
Old Aug 25, 2007 | 01:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Every time I relocate battery to trunk, starting power sux!
Size of the battery, age, condition? Size of the cable? Amp draw on the starter?
I've never had a starting problem from my relocated battery. I use 1/0 battery cable. My battery ground goes to a bolt that's welded to my roll cage. The engine doesn't have a proper ground. I should have a good ground cable from the engine to the frame or roll cage but my engine is grounded to the frame through the aluminum front motor plate. I use a Ford type starter solenoid mounted inside the car. There is no voltage going to the starter until the solenoid is activated. A simple loop of wire from the hot side of the starter to the starter's solenoid saves running the second wire to the starter. I have to use a mini starter because the huge headers prevent anything else.
Old Aug 25, 2007 | 02:17 PM
JesasaurusRex's Avatar
probably not big enough gauge cable, wouldn't go smaller than 1/0.
Old Aug 25, 2007 | 02:20 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
As stated above use 1/0 battery cable and get the good cable high strand tin covered cable crimp and solder the lugs also pay atten to you battery cut off switch a lot of the cheaper switches are not rated over 250 amps.
Old Aug 25, 2007 | 02:49 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have the summit 250 amp on/off switch along with the summit brand wiring kit and have no issues at all for cranking.
Old Aug 25, 2007 | 03:05 PM
thats cuz ur motor has has more blow by than jenna jameson's a*shole
Old Aug 25, 2007 | 03:19 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
I'd use the double 00 wire gauge that is primarily used for sound system amplifiers. I used to have a 4600watt sound system, and after I got rid of it I used that wire for a welder, and I have yet to find a use for it that it cant accomadate. its a bit expensive but well worth it.
Old Aug 25, 2007 | 03:38 PM
87_TA's Avatar
Hmmm,
Well I have been using the same Summit battery relocation kit in all of them..
The battery is brand new, and car cranks awesome when battery is under hood.. I would have to say it must be the guage of wire then, I don't know what guage it is but it must be 2 guage - thats what size the connectors are..
So that would sound like the problem then?
Old Aug 25, 2007 | 03:46 PM
yes it would
Old Aug 25, 2007 | 04:27 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
I would try new battery cables look for high strand count when looking at the wire on the end you want lots of smaller strands of wire versus big lower count of strands. also the wire that is silver in color is tin covered and will resist corroding better than copper.
Old Aug 25, 2007 | 06:23 PM
87_TA's Avatar
Thanks,
Just picked up some thin strand 1/0 from Lowes and some solder, its not fine strand but thin - wish it had been fine though for easier movement.
Old Aug 25, 2007 | 09:06 PM
87_TA's Avatar
Originally Posted by 87_TA
Thanks,
Its done and much better,
I have used this cable and box in three different cars, all of which never really started great.. But usually made up for with powerful starters thinking that was just the nature of a long power supply..
I was able to shorten the cable from 19' to 14', soldered the ends and went from 2 guage to 1/0 cable..
Thanks for help
Old Aug 26, 2007 | 09:54 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
For future note, we've always just used 2/0 welding wire/cable and have never had any troubles...heck, the cable in my car is 22' by the time it twists and turns through the car, and never a lick of trouble...plus it's cheap
Also upgraded yrs back to 4ga welding wire off the alt output direct to battery....this made the biggest positive upgrade I've ever done to a charging system...with all my electrical stuff running before on factory harness, volt guage was stuck in the high 12's/low to mid 13 volt...all i did was install larger ga wire to battery off alt and it immediately shot upto 15volt on the guage...14.78 on the multi meter...something else to look into/upgrade when time allwos if you run much electrical stuff.
Old Aug 26, 2007 | 11:36 AM
87_TA's Avatar
Good info!!!
I have been thinking of that! Especially since I run alot of accessories as well, ECM,Water pump, dual fans, Dual Fuel pumps, MSD, ECT.
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
