Firebird Plans
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Firebird Plans
Ok I am planning on building a firebird performance project in the future.
Here are my plans
Blueprint Engines 383CT Claimer 426hp/433tq at the flywheel
t56 transmission
3.73 posi rear
10-12 inch wide tires/rims in the rear 9 inch in the front
its going to be lowered 1 inch, by cutting some moog springs, I will be puting LCA relocation brackets, adjustable pandhard ber, some better sway bars, I am making the car for corners. I am going to try to get it down to 2800-3000 pounds.
Any idea what this would run in the 1/4 mile?
Here are my plans
t56 transmission
3.73 posi rear
Re: Firebird Plans
Here are my plans
t56 transmission
3.73 posi rear
Here are my plans
t56 transmission
3.73 posi rear
But with the weight and HP it is capable of trapping 120ish in good air. If your not close to that, your either not making the power or driving horrible, or weight is no where near 3000 w/driver or all of the above.
That number (3000lbs) will be hard to get also with big wide rims, Heavy suspension upgrades, wide tires, sub and strut tower braces ect.
Re: Firebird Plans
Also, any suggestions for an improvement in the setup would be appreciated. I need to figure out exactly what I want before I even start. I dont want to be buying parts that will end up limiting me in the future.
Also, the weight reduction Im not to worried about. I am plannign on removing almost everything. Back seats, carpeting all the interior trim. Basically all I will have is a custom dash on the drivers side with gauges and two front seats.
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
