what should my car run?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i've never been to the track but i'm itching to go now, and i was curious as to what i "might" run, i have a 305 5 speed with 3.73 gears, i dont know the weight of the car but i last dyno'd 381hp and 400 ft/lb's of torque, i have eibach prokit springs with tokico illumina struts/shocks and lower control arm relocation brackets, the run would most likely be on 255/50/16 mickey thompson et street drag radials.
is there a way to figure 1/4 mile time with the horsepower?
Car: 78 Z28
Transmission: 3500/th350
Axle/Gears: 5.13
Re: what should my car run?
there are a few caculators here you might want to play with.
http://www.freewebs.com/soslo/formulas.htm#hp_et_chart
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
High 12's would be my guess with decent traction. Shoot for some mid 12's though.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
381 at the wheels??? that should be anywhere from high 11's to mid 12's.. good luck getting the radials to hook better than a 1.7..
Car: 1986 Camaro SC
yes 381 at the wheels, i had some bfgoodrich drag radials but they are worn out now, traction is the thing, what would be the procedure on heating up drag radials? also air pressure, i try to take off and i just roast the tires
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Car: 1984 Trans Am
for a manual car, pressure is around 12-15psi.. burnout is a short one just to see smoke.. if you have a line lock, try preloading on the line.. it should help with the killing of the tires.. if not, try not to drop the clutch off the line.. ease it out and hope for the best..
i'll give you a 12.4 @ 110 estimate.. thats a pretty good run at 3600lbs..
http://www.tciauto.com/Products/Tech...alculators.asp
my car weighs in at about 3100 and has about the same power output as 86Z.. estimate is 11.63@116.. look at my sig.. its a combo of good driving, good traction and a consistant car..
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I made 371rwhp or something like that on a Mustang Dyno and run high 11s at 113-115mph at 3000'+ density altitude. It will really depend on your 60' though. You are sure maknig a lot of power per cubic inch.
Engine: 406sbc
Transmission: TH400
Thats what happens when you have a procharger. Damn I want one.
Car: 1986 Camaro SC
yeah the blower is the best, actually i'm hoping to put down more then 381 to the wheels soon.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
easy mid 12's, and theres plenty of guys running 1.4-1.5 60's on the MT DR's I will be running th 275/40/17 on my street tires
Car: 1984 Trans Am
there are alot of people runnin 1.4-1.5 60's but those are autos.. manuals are a different story.. best i've heard was low 1.6
1992 Trans Am
Aug 8, 2015 08:16 PM
